Old 02-22-2015, 06:43 PM   #1
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Throttle body
So I'm getting ready for Bo to work his magic and after pulling off my throttle body I can't help but think it should be cleaner than this. I guess this is why all of you say buy catch cans. Is this normal looking or should I be concerned?
Check out my build thread
Old 02-22-2015, 09:15 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Thats not bad at all. The catch can wont keep your TB cleaner, it will keep your manifold cleaner.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 02-23-2015, 03:41 AM   #3
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
looks almost rusty to me... mine was almost spotless, but i only had 20k on mine when i swapped it.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 02-23-2015, 04:06 AM   #4
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
How many miles are on that? My throttle body with 45k had a lil darker ring around it but the blade was still shiny. However I believe it only got the dark ring cuz the air intake was loose. I didn't have none of that "rust" or "washed up" look on the blade.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 02-23-2015, 06:22 AM   #5
Bo White
Bo White's Avatar
I've seen some like that.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-23-2015, 06:54 AM   #6
pyroguy
pyroguy's Avatar
Drives: ABM #832
36k on the clock. So it isn't brand new anymore, but still not THAT many miles. (I keep vehicles 170k+ miles typically.) Just was wondering about how typical this was and if having a little oil on it was normal or not.
