Old 02-22-2015, 08:35 PM   #1
ToddB
Drives: 2011 2SS Convertible Supercharged
AEM Water/Methanol failsafe gauge
Anyone running one of these gauges with your Alky Control meth system. AEM Water/Methanol failsafe gauge http://www.aemelectronics.com/produc...failsafe-gauge
What are your thoughts and how do you have it hooked into your tune? Thanks.
ToddB is offline   Reply With Quote
Old 02-22-2015, 08:39 PM   #2
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Mine is set up so that if I run out of meth, or if it fails. and I'm spraying less then I should, the car will fall flat on its face. I have a level indicator that tells me when I am getting low. Matt has the car built and tuned for it.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
