Old 02-23-2015, 09:25 AM   #1
NJScorpio
NJScorpio's Avatar
Drives: 2018 Camaro 1LT Hyper Blue Metallic
Any negatives to a CAI?
This question may vary depending on the model, I'd imagine.
But I was wondering, lets say you have a CAI, is there anything you should avoid (or do in particular)?
There was one I saw that appeared to have an intake tube aimed downward, with a cone filter (not in a box to the side like other CAIs), and I thought that'd be a problem if you end up going through high water.
I may be 100% wrong.
NJScorpio is offline   Reply With Quote
Old 02-23-2015, 09:28 AM   #2
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Most of the submersion issues have been solved. For example, the racing scoops made by Apex, JRE, and others have special holes in the bottom to let out any water before it hits the intake.
You can also add an Injen Hydro-Shield, a water resistant cover that slips over the filter.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 02-23-2015, 09:35 AM   #3
19car69
19car69's Avatar
Drives: 2012 1LS
Only negative I have seen is the stupid goofy grin on my face all the time. If you can get past that, it is all good.
2012 1LS, Cold Air Inductions CAI, Apex scoop, Apex water bottle relocation, VMax Ported TB, Vitesse Throttle Controller, BMR Sway bars, BMR 1.2" drop springs, Koni rear shocks, Elite catch can, Solo Performance V6 Mach X-LFX Cat-Back Exhaust, Hex Vents, 1LE strut tower brace, Barton short throw, separate clutch reservoir, American Racing TORQ THRUST M 18X9, HiTS radio with reverse camera, GM Blade Dovetail spoiler, 2010 leather wrap steering wheel, vented engine cover, added Homelink to overhead console.
19car69 is offline   Reply With Quote
Old 02-23-2015, 09:41 AM   #4
pickwithaustin
pickwithaustin's Avatar
Drives: 2011 Camaro 2SS/RS Convertible and:
Just the same old rule of thumb for everything else in life: "You get what you pay for."
On a side note, don't take your Camaro through "high water," regardless.
Currently in my Garage:
2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i
pickwithaustin is offline   Reply With Quote
Old 02-23-2015, 09:52 AM   #5
NJScorpio
NJScorpio's Avatar
Ah, that's very true.
While I have no expectations that my stock Camaro is Jeep Trail Rated or anything, I just didn't know if changing the stock intake just made it more likely that an inadvertent undercarriage soaking would get into the air intake.
Old 02-23-2015, 10:00 AM   #6
pickwithaustin
IDK. My CAI is enclosed.
Old 02-23-2015, 10:12 AM   #7
stoopid
Drives: 4 wheels
The oiled filters let in more particles, jury's out on whether that matters much in the long term/life of the vehicle.
Not sure how loud a CAI on a Camaro would be, but my experience is that it's a pretty loud add-on so you better like the noise it makes.
Water, even splashes, won't likely make it up that far in the engine bay to matter. Look at your engine bay right now. Do you see evidence of water getting anywhere near the current intake box?
stoopid is offline   Reply With Quote
Old 02-23-2015, 11:45 AM   #8
NJScorpio
NJScorpio's Avatar
Is it the Injen intake that I'm thinking of that seems to just stick downward?
Old 02-23-2015, 11:59 AM   #9
bowtiesonly
bowtiesonly's Avatar
Drives: 2012 Camaro 2ss
Yes you are correct. The filter sits directly behind the fog light area on the injen longtube intake.
2012 2ss , long tube headers , summit x pipe ,borla mufflers, vararam intake, vmax ported throttle body rdp motorsports dynosteve tuned, BMR trailing arms and bushings elite engineering catch can. [Ifirst camaro ]2012 LT LFX, nytrex wet system ,GPI dyno tune, Injen longtube intake, Dynomax axle back exhaust, Vmax ported throttle body, elite engineering catch can.
bowtiesonly is offline   Reply With Quote
Old 02-23-2015, 03:10 PM   #10
snymat68
snymat68's Avatar
Drives: 2013 Blue Ray 1LS M6
Downside = less money in wallet
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller
Aesthetic Mods
Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items
snymat68 is offline   Reply With Quote
Old 02-23-2015, 03:20 PM   #11
NJScorpio
NJScorpio's Avatar
Ah, thanks! With that name, I was able to find it, and see that it has water guards for it.
Old 02-23-2015, 04:44 PM   #12
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Downsides, no way!
Speaking of water intrusion, many people do not know that our Cold Air Intake goes through extensive water intrusion testing, where droplets of moisture are tested for on a microscopic level. They don't actually look for droplets with a microscope, they have teting equipment that measures any water intrusion, but I think you get my point All of our intakes are designed so that water intrusion will not be an issue under normal driving conditions. There are intakes that place the filter in areas that are not the best location, and there have been stories of hydro-lock involving some of those styles, with our CAI that issue is non-existent.
Sales @ CAI Inc is offline   Reply With Quote
Old 02-24-2015, 02:08 PM   #13
newb
newb's Avatar
Drives: 2013 1LE
I have seen a noticeable decrease in my gas mileage. This may be due to the uncontrolled urge to get on the gas but I blame the intake. That's my story and I'm sticking to it.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 02-25-2015, 11:42 AM   #14
Sales @ CAI Inc
Thank you for choosing Cold Air Inductions Inc.! Nice looking engine bay!
