Old 02-23-2015, 01:13 PM   #1
Jessevas248
Drives: 2014 white Camaro ss
Question I need some input on my mods
Hello I need some input on what I should get done to my 2014 camaro ss. I want to get an axle back but I don't know whats a good brand to get iv been told borla and flow master outlaw is good. Also I want to find a good cold intake its between K&n, CAI , and airaid. Thanks for your input
Jessevas248 is offline   Reply With Quote
Old 02-23-2015, 01:16 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
K&N sucks to dump that out of the list
62nalide is offline   Reply With Quote
Old 02-23-2015, 01:20 PM   #3
BRAVO 2SS
Aim Small...Miss Small
BRAVO 2SS's Avatar
Drives: 2018 ZL1 M6
+1
2010 Camaro 2SS/RS
BRAVO 2SS is offline   Reply With Quote
Old 02-23-2015, 01:29 PM   #4
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Go with CAI or RotFab
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 02-23-2015, 01:38 PM   #5
forklord
forklord's Avatar
Drives: 2010 2SS
In my opinion an intake is a waste of money. Use that money On some longtube headers
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 02-23-2015, 01:38 PM   #6
BrutalSS
BrutalSS's Avatar
Drives: 2010 Hennessey Camaro
I really like the GMPP axle backs, nice sound with factory headers/exhaust. I have them on my camaro.
BrutalSS is offline   Reply With Quote
Old 02-23-2015, 01:48 PM   #7
Camarojt
Camarojt's Avatar
Drives: 2011camaro SS
You will want a good CAI to go with a set of headers. You will always here that the basics to all modding is Air in Air out. Let your engine breathe. To say that a Cold Air Intake is a waste of money is just a ignorant statement.
But don't buy a K&N if you value performance. Stick with higher quality CAI's like ADM, Roto Fab, New Era etc...
These are much more race proven.
Unless your buying based soley on looks. Then pic what you like.
Camarojt is offline   Reply With Quote
Old 02-23-2015, 04:05 PM   #8
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Here we go again. There are proven HP gains with the addition of many of the Cold Air Intakes. CAI and Rotofab being the best without requiring a tune. Naturally aspirated engines LOVE cold air - something about the air/fuel mix efficiency improves at lower temperatures, I don't know all the specifics.
I have a CAI, Inc intake and the Apex air scoop and although I don't have before and after dyno readings, I can assure you the punch in my engine improved with the additions. I can only assume I gained a bit of HP with the mod.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 02-23-2015, 04:57 PM   #9
aFe POWER
aFe POWER's Avatar
Drives: Camaro
Also please consider us here at aFe POWER, we have both intakes and exhaust systems for either V6 or V8 camaro's
aFe POWER is offline   Reply With Quote
Old 02-23-2015, 05:16 PM   #10
Scooter18155
Scooter18155's Avatar
Drives: 2010 ss/rs 6 speed manual
This is ignorant like others have said. It may be true long tube headers will give you better gains but the cai others have suggested like cai, adm performance and others will show you improvement. When I installed my adm race intake I gained not only some power but a better sound from my exhaust as well. Deffinately do a air scoop with the intake as well. The intake will only compliment long tube headers if you decide to buy some later.
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
Scooter18155 is offline   Reply With Quote
Old 02-23-2015, 06:11 PM   #11
forklord
forklord's Avatar
Drives: 2010 2SS
Im just saying id get headers before an intake. Way more hp/$. Get headers first then get an intake. Intakes are more for peak power. Headers will give you results across the power band
Old 02-23-2015, 06:20 PM   #12
Scooter18155
From what I've read headers require a tune at the very least to get the most bang out of them. It would be better to do all the smaller (non tune mods) first and out of the way so when headers is added and tune done the smaller parts that compliment headers and bigger changes will be present and taken into consideration when tuned. $ per hp/torque you may be right about headers vs intake but intake isn't an overly expensive mod to do.
Old 02-23-2015, 11:15 PM   #13
The_Blur
Moderator
The_Blur's Avatar
I went with CAI, and, like their other customers here, I'm thrilled with that intake.
As for an axleback, I originally installed a Pypes system. I wanted something with some noise and no mufflers. It had a great sound, but I ultimately chose to go with a complete catback system and removed it. It's still for sale if you want a used system.
warn 145:159 ban
Old 02-24-2015, 12:34 AM   #14
Jessevas248
Thanks for the input and how much are u asking for it ??
2014, cai inc, flowmaster exhaust
