Old 02-24-2015, 01:21 PM   #1
martin_2010
martin_2010's Avatar
Drives: 2010 Camaro 1ss/Rs package
Exclamation camaro with either battery or alternator problem help
So I bought a new battery for my 2010 camaro ss cause they told me my old one was bad and I had been having problems getting my car started so now it's doing it again I go and turn my key and it clicks and completely goes dead.. everything was working fine until the temperature dropped Monday morning that's when I started problems again. I came to auto zone today to have my battery checked and they told me I have a bad alternstor.. but my concern is why do I only have this problem when it's cold.. and when it warms up everything works perfectly fine ?
When I get my car jump started it starts like normal as well.. maybe someone out there can help me out
martin_2010 is offline   Reply With Quote
Old 02-24-2015, 02:47 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Everything was working fine until the battery was drained because the alternator wasn't charging. Not because it's cold..coincidental ....it's a shame they didn't check the alternator when they checked the battery. You probably only needed the alternator ...silver lining.... You would have been replacing the battery sooner than later
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 02-26-2015, 12:12 PM   #3
martin_2010
This is what the computer shows any ideas what it might be ? Starter?
P0336 crankshaft position
Sensor A circuit
range/performance
Old 02-26-2015, 12:15 PM   #4
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Its probably the battery.
I had the exact same issue with mine.
I replaced the battery. the issue reoccurred.
I bought a float charger (Battery Tender Jr.) at walmart for around $30, issue solved.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 02-27-2015, 10:49 AM   #5
martin_2010
That's all you did , ? I will try this today If it dosnt work I will be taking it in to dealer
Thanks for the tips
Old 02-27-2015, 10:56 AM   #6
Spartan01
Spartan01's Avatar
Yes, that is all I did.
I replaced the original 2010 battery.
The issue kept happening. So I bought a float charger.
A float charger is just a trickle charger that stops charging when the battery is full.
They make a bunch of different ones.
I use the Battery tender Junior, it was about $30 and you can get this model at most auto parts stores or Wal-Mart.
Also, uou may need an OUTDOOR extension cord. Again, $10-$30 at Wal-mart
These cars, the computer stays on all time, and will slowly drain the battery.
This issue gets a lot worse when it is cold, and when you do not drive the car every day.
Old 02-27-2015, 04:46 PM   #7
martin_2010
They just checked my battery and said it's good that it'd at 90%.. but I turn the ignition and no gauges come on or anything help
Old 03-03-2015, 06:49 PM   #8
martin_2010
I checked voltage to battery and it's charging battery to about 14.9 which isn't normal ... it also fluctuates alot from 14.9 to 13 to 14.2 and back 5 o 14.9
engine, starter
