![]() Drives: 2018 LT Join Date: Nov 2014
Sun roof stuck open
Hey guys...
Just opened my sun roof after washing my car and now it won close. Don't think it's the fuse, I took it out and put it back in. You can hear a click when you press the buttons like it's trying to close but won't move...
![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS/RS Join Date: Oct 2013
Check the track to see if something fell onto it. Someone here had a similar issue a few years ago.
http://www.camaro5.com/forums/showthread.php?t=218939
Yes. I saw that thread. I'll take a closer look in the day time, thx!
Any other ideas? |
![]() Drives: 2017 RS Redline Edition Join Date: Dec 2014
get it looked at and park in a garage until then lol. Good Luck!
Is there any way to fix this myself?
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Evil Eva, 2010 2SS LS3 Join Date: Aug 2013
Try wiggling it at the front edge.
Lots of times the sunroof itself is at a slight angle and is grinding against its own side rails. Or there can be something in the track. Also try pushing the open button, then the close button several times in a row. You can also try GENTLY pulling the sunroof forward while pressing the close button.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
#7 |
#8 | |
Lol... Sunroof stuck? Just wiggle it.. sure! Thanks bro you just saved me $60 (inspection). Why on earth is it possible for this to happen? Seems like cheap design for it to become stuck from becoming slightly off center!
#9 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Sometimes, sunroof assemblies over time can develop some play... So it may pull back farther than it normally would. This combined with the grease being displaced in the track leads to the sliders in the sunroof rails getting to an unlubricated spot on the slide. Then they bind.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
#10 |
Hey man, you are welcome.
I don't know why they make them like this, I can only guess that it is not so much a fault of the sunroof itself, but that the body flexes ever so slightly resulting in the sliding being a bit off kilter. I have had this in almost every car I have owned that had a sunroof.
#11 |
![]() Drives: 2013 RS Camaro, Rally Yellow Join Date: Apr 2018
Did you figure ouot what was wrong with your sunroof...I bet you have its been a few years. Mine just stuck open today. I have pulled the fuse and even the switch(pain in the rear if you have never done it). Normally a switch is switch and it appears there might be a problem with it. Wanted to short the contacts but am a little worried not just be a switch. Anyway can you let me know what your problem was? Thanks (2013 Camaro RS)
Frank-0 |
#12 |
Similar issue....
I had a similar issue with my 2011 LT. Sunroof stuck open a couple different times. The first time fiddling with the switch open/close got it working again. The second time it stuck I decided it was the switch, so I ordered a new one an replaced it. It was good for about another 4 - 5 months and then it stuck again. What seems to have fixed it for good is some good old Lithium grease. After washing the car I opened the sun roof and cleaned the tracks really good to remove any dust/dirt/grime buildup. Then it put a liberal amount of lithium grease in the tracks and opened/closed the sunroof several times. I noticed the sunroof now appears to move much smoother than it previously did. I also use my sunroof a lot. I'm not sure what the recommended interval for lubricating it is, but this is a good place to start if yours starts sticking.
#13 |
![]() Drives: 2010 2LT Victory Red Join Date: Sep 2011
Lube those rails to keep it from happening again .
Previous Vehicles
1970 Impala 2D 350/300 1972 Buick GS 350 1967 Pontiac Firebird 326 1969 Chevelle SS 396/375 I really miss this one 1966 Chevelle SS 396/350 1978 Plymouth Fury 440 1982 VW Scirocco ( Got married ) 1987 VW Scirocco 1992 Ford Taurus V6 1996 Dodge Intrepid 2002 Dodge Intrepid 2002 Mercedes ML500 2010 Camaro 2LT |
