I run 2 catch cans...
Drives: 2012 1LT SIM Auto Join Date: Oct 2011
DIY: make your own replacement Windshield Washer Bottle
This is a DIY for those of you who have installed an air scoop for a cold air intake, and have lost the option to wash your windshield as a result. This is an easy to follow pdf guide with lots of pictures.
The write-up is also available starting at post #7.
Overkill tuned Air Scoop CAI VMAX PTB JacFab Laminator FX + Extendolator SOLO Hi-Flo Cats + Cat-Back Exhaust
View my top 3 LFX performance mods and more: . Last edited by yzark99; 03-01-2015 at 10:49 AM. Reason: fixed typos |
Silver Ice
Drives: 2011 1LT Coupe SIM Join Date: Nov 2013
Thanks for the write up. I don't download files from none secure sources. No offense meant at all. Very interested in this. Can you paste into the forum please?
The pdf was uploaded and attached through this same page on C5, so it should be secure. It has now also been posted in this thread as pictures and info.
View my top 3 LFX performance mods and more: . Last edited by yzark99; 03-01-2015 at 10:49 AM. Reason: updates |
![]() ![]() ![]() Drives: 2013 Blue Ray 1LS M6 Join Date: Apr 2013
This is an interesting idea, but why not just get the Apex washer bottle relocation tank? I have it. It's a half gallon and it's annoyingly small. The water bottle is 4x smaller yet. I would think you'd be refilling it every 10 squirts?
Performance Mods
Elite Catch Can | CAI Intake with Scoop & Washer Bottle Relocation | MRT v2 Axle-Back Exhaust | MagnaFlow Resonated X-Pipe | Resonator Delete | Vmax Ported Throttle Body | GM Strut Tower Brace | JDP Tow Hook | Vitesse Throttle Controller Aesthetic Mods Chrome Peek-A-Boo Door Handles | Interior Accessories Kit | OEM RS HIDs w/ 6000k Bulbs & 5000k LED Fogs | Tail Light, Marker Light, & Turn Signal Tint | Tru-Sequence Sequential Turn Signals & Brake Lights | Silver Fade Gill Stripes | Carbon Fiber Bowties | Various Chrome/Painted/Carbon Fiber Items |
![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Because it cost $70 and he has the satisfaction of a DIY. I removed my washer bottle so 10 squirts could last me a long time, even if it was just for an emergency. I could see if you are a DD, this might a pain to constantly refill. But for occaisonal use it's an inexpensive solution.
#6 |
Considering that I only used the fluid maybe twice last year, 10 squirts will last a long time. That was only a rough estimate; the bottle might actually have 40 squirts in it. YMMV.
View my top 3 LFX performance mods and more: . |
#7 |
Here's the full article for those of you who need it:
Build your own replacement windshield washer bottle for under $15.
If you put an aftermarket air intake in your camaro, and then later decide to install one of the air scoops to help it out, they require the removal of the stock washer bottle. You can then either have no bottle, install a bottle from Apex $$ or Roto-Fab $$$, or make your own. The OEM bottle can hold over a gallon of fluid, which weighs about 9 pounds. If you use a liter bottle, weight drops down to 2 pounds, and a 500 ml bottle weighs about a pound. I figure even the smallest bottle should be good for 6-10 squirts to clean the windshield. 3 bottles shown: left is OEM, middle is my first white liter bottle, and right is my new smoke 500 ml bottle.
#8 |
This is my 2nd bottle fabrication. I originally started with a liter bottle that I had lying around. It was a white color, and while this made it easy to see how much fluid was in it, it also added another white bottle under my hood that really stood out from the darker engine parts.
#9 |
I found a neat smoke colored bottle from Outdoor Products at Walmart for $3.50. They also have a liter bottle for a few cents more. The bottles are available in smoke (black), red, blue, yellow, green, pink and maybe some other colors too. They are translucent so that you can see fluid through them. If you want one of these bottles, I suggest that you rush over there, as they are being closed-out.
(white adapter is not included)
#10 |
I bought 4 plumbing pieces after reading about the best way to prevent leaks. A male threaded plug, an o-ring, a double threaded female socket, and a male threaded 1/2 to 3/8 adapter.
These are in 1/2 sizes, which are the smallest sold. 1/2 means that it will accept a 1/2 pipe; not that it is 1/2 diameter. It is a little over 3/4 diameter. Plumbing parts are strange, in that threads are tapered. The farther you turn them, the tighter they get. If you screw them all the way in, there is a strong possibility of breaking the parts. I sanded the socket smooth where it screws against the bottle (o-ring side). You can also use metal parts to replace these 4 pieces, which will be smaller; but the price will go up substantially.
#11 |
I drilled a smaller hole in the bottom of the bottle, and sanded it out with a dremel, and then used a hand sanding sponge out to the finished size. I also used the dremel to route out a drain thru the top of the closed male threaded plug, then mounted the o-ring on it.
#12 |
Final assembly has the plug and o-ring inside the bottle, with the female socket outside, screwed hand tight to the bottom of the bottle, then 1/3 turn more with pliers.
The adapter is screwed into the bottom with teflon tape over the threads; hand tight. Liquid would have to get past the o-ring to leak down the outside of the adapter, but easily flows through the adapter into the wash line.
#13 |
I had made a bracket for holding my previous white bottle, from 4 pieces of flat clamp that I got for a dollar. I bent them into shape using a vice and a hammer. I bolted it together so that it would fit over the old air cleaner stud. I bent the bottom to support the bottle, and bent 2 arms to hold it in place. I then wrapped it in electrical tape to hide the shiny metal.
View my top 3 LFX performance mods and more: . Last edited by yzark99; 03-01-2015 at 10:55 AM. Reason: clarity |
#14 |
I use a flat washer and a nut to hold it in place.
| Tags |
| diy, inexpensive, mod, plastic, wash tank |
