Old 02-28-2015, 04:27 PM   #1
ericchang
Drives: 2015 Camaro 1LT/RS
camaro pypes cat backexhaust 2015 v6
Hi guys. I bought the pypes cat back exhaust for the ss for my 2015 camaro v6. I was told by pypes exhaust themselves this would fit my camaro v6, and by phastek that the exhaust system on the 2015 camaro was same as the one from the 2010 v6 from the cats. Today, I tried to install, and the angle pipes connecting to x pipe and cat converters, were too wide. What do I do? Will phastek refund my money and shipping?
ericchang is offline   Reply With Quote
Old 02-28-2015, 04:36 PM   #2
Blazer098
Blazer098's Avatar
Drives: 2015 Summit White SS
Sorry, but why are you asking here. Call them up and tell them, they'll get it all sorted out.
Full Bolt-Ons w/ Nightfury Cam (471rwhp)
Blazer098 is offline   Reply With Quote
Old 02-28-2015, 05:58 PM   #3
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
sure you don't have the pipe sides reversed ???? I have the Pypes for my '13 2LT and like the system but a ton of drone .....
mr02Z/28 is offline   Reply With Quote
Old 02-28-2015, 06:07 PM   #4
mr02Z/28
@ WOT the Pypes system sounds really good ........ my wife finally got use to drone it creates ....
Old 03-01-2015, 01:39 AM   #5
TravisLBoston
Drives: 2012 Camaro v6 LFX
I also have pypes for the camaro if the agle is to wide I flipped them around and it lined up but I have a problem with what sounds like a rattle inside the mufflers any one know or have same issue? I don't think they will have warranty on them anymore cuz I originally thought it was vibrating off the tunnel brace or the tunnel it's self so I took it in and got them welded in and when it was all welded in there was less rattle but still a sound coming from what seems to be inside the muffler any idea?
TravisLBoston is offline   Reply With Quote
Old 03-01-2015, 06:57 AM   #6
Kyle1228
Kyle1228's Avatar
Drives: 2014 Camaro 2LS Summit White
The guy that installed mine had to push the heat sheild up away from the exhaust and tried bending the tunnel brace. It still would hit the brace on every little bump, so I got an aftermarket tunnel brace and some spacers and that seemed to solve it. except for the random bigger bump that still makes it hit.
Even though the fitment isnt the best, mine ended up perfect for my quad tips. And I love the sound, the idle is awsome and i dont mind the drone.
Kyle1228 is offline   Reply With Quote
camaro, cat-back, exhaust, pypes
