Old 03-01-2015, 03:24 PM   #1
BigBlock427
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1
ADM LSA Conversion qustions....
Some quick questions as I am very interested in the kit...
I just paid off my 2011 2SS/RS. it has around 30,000 miles on it currently but since I got a new job much much closer to home and have a daily driver... I wont be putting allot more on it in the near future.
so my first question... is the millage something to worry about? meaning is supercharging this late in the game a sketchy deal??? i know the risks "it could blow the first day or at 100,000miles"
and now more specifically about the ADM LSA kit...
I would be buying the complete kit with a new supercharger... bedsides the kit what else do I need in the long run? 65lb injectors, zl1 fuel pump, and obviously tuning... do I need the injectors and fp right away? or can I push enough fuel safely with the stock LS3 equipment?
thanks in advance.
BigBlock427 is offline   Reply With Quote
Old 03-01-2015, 04:29 PM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
The best advice I can give you even if you don't plan on modding any further....
Add the fuel system that will give you room to grow. if you ever want to add a cam or pulley down, you won't be buying parts twice. So I'd personally go with the 65s or even better yet the 80lb injectors with the zl1 pump/ adm fpcm
You will thank yourself later!
try to find a lower mileage blower if possible or I'd it's a big deal buy the complete kit from adm. Just my 2 cents
If you do buy a higher mileage one I would get the bearings changed in it for peace of mind
ttshovel is offline   Reply With Quote
Old 03-01-2015, 04:42 PM   #3
LTRS777
LTRS777's Avatar
Drives: 2014 Saleen 620 White Label #14-011
thanks in advance.
It's an oem piece... One of the main reasons I want to go this route. Although not an lsa engine, i can't imagine it have much less reliability than a bolt on zl1. Done right I don't see why it can't make 100k.
Adm I'm sure can answer the rest. at stock pulley I was told stock injectors were fine. Fuel requirements will be dictated by your power goals. Gl!
'14 Saleen 620 White Label #14-011
ADM LSA Stage 1 Kit, ADM 2.75 Pulley, DEKA 63lb injectors,
ZL1 Fuel Pump, JLT 123MM Big Mouth intake, TSP 2" LTHs,
BW TB, 2.5" Catback, Scott Culbert/GEN3PERF tuned!
573WHP/557WTQ @ 10psi.
Build Thread Here: http://www.camaro5.com/forums/showthread.php?t=390708
LTRS777 is offline   Reply With Quote
Old 03-01-2015, 05:35 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
I have 40k on mine and did cam, heads, and the LSA kit. Did the zl1 fuel pump and adm Fpcm and I Love it. therse engines can handle the upgrades if properly installed...
-Don
747 RWHP 794 RWTQ
Old 03-01-2015, 09:49 PM   #5
ADM PERFORMANCE
Drives: Anything I want
thanks in advance.
This is a very solid kit for a very mod friendly engine.We have been pushing the envelope of performance since 2009(6 years) with this car.Its nothing NEW so you have little to worry about if you stay within the limits(600hp or less) of your engine.
As far as laying a great foundation for future...Fuel Pump can only help not hurt...Injectors can Only help not hurt.New 1 step colder spark plugs can only help not hurt as well as a good cold air intake and headers.
Hope this answers your questions and builds the confidence your looking for.
ADM PERFORMANCE is offline   Reply With Quote
Old 03-02-2015, 11:51 AM   #6
Juice2SS
Drives: 2011 2SS
I went with the setup at 45k miles. Car is strong and easily outperforms my previous setup. I made sure to go with the upgraded injectors and fuel pump. No use in not being smart about it.
Juice2SS is offline   Reply With Quote
Old 03-03-2015, 01:35 PM   #7
BigBlock427
ConceptZer0
thanks for the info guys. Just sucks you guys are in Texas...
Old 03-03-2015, 03:27 PM   #8
hammdo
hammdo's Avatar
Well, I did mine myself, so you sure can do it!
-Don
747 RWHP 794 RWTQ
Old 03-03-2015, 03:38 PM   #9
smokum
smokum's Avatar
Drives: 2010 2ssrs
Andy ships cars all the time. You would be surprised on the price to ship your car to texas and have them do it. Im sure andy would work you a great deal on it sending it down for an install and maybe some other mods. Shoot him a message or give him a call.
smokum is offline   Reply With Quote
Old 03-03-2015, 05:26 PM   #10
rickdallas
rickdallas's Avatar
Drives: 2010 CGM 2SS RS
Andy installed his kit on mine with stock cats, Borla Touring exhaust, stock ZL1 fuel pump and intake. Very manageable setup for the street and not too expensive to start out with. LOTS of power over stock and the CAI and headers can be added later, when you're ready.
ADM / LSA CONVERSION, ZL1 FUEL PUMP, BMR SWAY BARS AND TRAILING ARMS, ADM UPPER CONTROL ARM BUSHINGS, BORLA EXHAUST, FR 20X10-275, 20X11-315 NITTO INVO'S
rickdallas is offline   Reply With Quote
Old 03-03-2015, 10:28 PM   #11
ADM PERFORMANCE
They come from every where
I have one in route from Washington , Its 2026 miles and the cost is a little over $1000.00
All things considered its not a bad deal
Old 03-04-2015, 03:53 PM   #12
BigBlock427
ConceptZer0
I might just start ordering the support stuff. injectors, ZL1 FP, Kooks 2" headers and then get the ADM kit. Throwing everything on at one time. reliability is like top priority...I don't daily the Camaro.... however like anyone I don't want to spend more time down then driving the car. so with that said I rather do the fuel support now. and other support modification I can do? meaning with reinforcement in mind over making more power.
Old 03-04-2015, 04:04 PM   #13
hammdo
hammdo's Avatar
Suspension if you've not done any. Trailing arms/bushings, cradle bushings (inserts, poly replacements, or solids - depend on what you intend to do with the car). Inserts are fine if you are limiting use, but solids would be first choice if not using inserts. I DD mine so I went with inserts since tracking/racing is limited.
BTW, ADM does have the solids. Inserts I used BMR
-Don
747 RWHP 794 RWTQ
Old 03-04-2015, 09:08 PM   #14
BigBlock427
ConceptZer0
well guys thanks for the help. I ended up finding a ZL1 for a amazing price. I put down a deposit and will hopefully be picking her up in a week. thanks again!
adm, ls3, lsa, zl1
