Old 03-01-2015, 07:37 PM   #1
seven
seven's Avatar
Drives: 2015 Camaro RS 2LT AGM
Elite Catch can Install help hoses
I have looked through video's and posts on installing Elite Catch Can. How do you know where(meaning how far down the hose) to cut the hose line? How much of the original hose do you leave?
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions)
seven is offline   Reply With Quote
Old 03-01-2015, 10:08 PM   #2
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
This is mine, hope it helps.
hzisfrom1994 is offline   Reply With Quote
Old 03-01-2015, 10:25 PM   #3
Pathogen
Pathogen's Avatar
Drives: 2014 1LS Camaro
I think you are asking about where to cut, so: on the rear fitting, I actually cut the hose enough to remove it from the fitting. It basically peeled off. The front fitting, I cut the hose about one inch from the fitting. Basically, just leave enought to get a good seal on the hose when you slip it together.
Nobody with a good car needs to be justified. -Flannery O'Connor
Pathogen is offline   Reply With Quote
