Old 03-02-2015, 02:07 PM   #1
jesse454545
Drives: 2011 CAMARO 2SS/RS
1LE 3.91 Install Question
How hard is it to instal the 3.91 1LE Gears into a 2011 camaro LS3 and if it is possible does someone have a write up on how to do it? Also is this something someone can DIY or is it something that needs to be done in a shop?
jesse454545 is offline   Reply With Quote
Old 03-02-2015, 04:48 PM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Yes the 3.91 gears can be installed in any SS. However, it is not a DIY job. Installing gears is an IRS rear end is a pretty complicated 6+ hour job even for a professional.
Old 03-02-2015, 04:51 PM   #3
jesse454545
okay i thought it was a simple swap of gears but i guess not. Is there anyway to verify what kind of gears you have in the rear end. I bought my car used and it had alot of modifications already and not sure if thats one of the things he modified. im still finding modification and its been 2 years since i bought the car lol
Old 03-02-2015, 05:56 PM   #4
Stock Ain't Fun
Drives: 2015 2SS 6M Coupe
There are several videos on YouTube that show you how to determine gear ratio. Find one that suits your needs.
2015 2SS Coupe LS3 6M
Stainless Power Headers with Cats
CAI Inc. Air Intake
JRE Tune
Stock Ain't Fun is offline   Reply With Quote
Old 03-02-2015, 05:57 PM   #5
Scooter18155
Scooter18155's Avatar
Drives: 2010 ss/rs 6 speed manual
I believe there is a way by disconnecting your driveshaft spinning your wheel 1 revolution and counting the revolutions on your rear end where drive shaft connects. Not 100% sure exactly how this works (I've never done it just read about it) but I'm sure someone else may know and comment
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
Scooter18155 is offline   Reply With Quote
Old 03-03-2015, 01:59 AM   #6
avido
Drives: camaro ss\rs
hi.saturday i got my gear sswapped. it.s a real pain in the ass. 5h of job. it's not complicated but you have to use a correct preload for the bearing use a specific tools and check if everithing is ok before reinstall on the car.
avido is offline   Reply With Quote
Old 03-03-2015, 08:20 AM   #7
EM1/SS
Drives: 11 2SS/RS M6 vert
You should be able to figure it out based on what gear your in, your speed, and your RPM.
LSA supercharger, Borla S-Type cat back, BMR/ Pedders Suspension, Kooks stepped LT's, GM 3.91, and RDP tune.
EM1/SS is offline   Reply With Quote
Old 03-03-2015, 08:32 AM   #8
lownslowss
PaPa Smurf
lownslowss's Avatar
Drives: 2022 SS 1LE
I can't believe there's not a tag on the diff.
2022 Rapid Blue SS 1LE
lownslowss is offline   Reply With Quote
Old 03-03-2015, 12:45 PM   #9
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You spin the drive shaft and count how many revolutions it takes to turn the wheels one revolution. The number of times you turn the driveshaft is your gear ratio, e.g. almost 4 revolutions would be a 3.91, 3.5 revolutions a 3.45.
1le, 3.91, gears, torque
