Old 03-02-2015, 04:17 PM   #1
Jester06
Drives: 2013 White L99 SS
Slotted Vs. Drilled Rotors
So I'm looking at new rotors soon, and was wondering which is better, drilled or slotted. What are the differences and are there any pro's and con's between the two?
Current HP/Torque: 413HP/413 Torque
Current mods: Pfadt Tri-y Headers with Hi-Flow Cats, VMAX CNC Ported Throttle body, CAI intake by Cold Air Inductions, Apex Air Scoop/Washer relocation set, RX Catch Can, Stainless Works 3" retro Chambered cat back exhaust, Flex Fuel sensor, 3.91 gear ratio, BMR rear trailing arms, BMR Rear Toe rods
Future Mods: GPI's SS3 VVT cam, 3600 stall triple disc torque converter, Fast LSX 102mm throttle body
Jester06 is offline   Reply With Quote
Old 03-02-2015, 04:31 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
General consensus is that slotted are better. The slots are more efficient at removing gas buildup and are less prone to cracking.
I have slotted/dimpled rotors on Bee. Same effect as both, but doesn't have the cracking issues of drilled.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-02-2015, 05:11 PM   #3
Jester06
I was looking at Brembo rotors but what are some other good brands to go with?
Old 03-02-2015, 05:12 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Drilled are very prone to cracking, even when cryogenically treated. I would suggest Slotted!
Old 03-02-2015, 05:49 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This.
Old 03-02-2015, 05:54 PM   #6
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
You need new rotors on a 2013? How many miles have you put on that thing?
Unless of course you just are looking for something different looking.
Like said, drilled are prone to cracking, but I will say I think most of the cracking is when used very heavily like on the track. Slotted is better though, just make sure they aren't the kind that are slotted all the way through.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 03-02-2015, 06:02 PM   #7
UF4LIFE102SS
Treasure Coast Camaro 5
UF4LIFE102SS's Avatar
Drives: 2010 2 SS
I got R1Concepts drilled and slotted.
Old 03-02-2015, 08:01 PM   #8
Jester06
I was looking for some newer ones for when tax refund comes in, and was just curious the difference
Old 03-02-2015, 10:27 PM   #9
Merc
In The Circle
Merc's Avatar
Slotted only is the way to go, drilled can crack. I have DBA's on Pumpkin, two piece on the front, I track regulary.
Old 03-02-2015, 10:31 PM   #10
Merc
In The Circle
Merc's Avatar
Old 03-03-2015, 02:03 PM   #11
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Our brake special is back.
Purchase any of our Rotors and receive free pads.
http://www.camaro5.com/forums/showthread.php?t=257770
Let me know if you have any questions.
Thanks
JT
Team STILLEN is offline   Reply With Quote
Old 03-05-2015, 04:40 PM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I've seen Brand New Drilled Rotors with tiny hairline cracks
Old 03-05-2015, 04:52 PM   #13
Rob@WretchedMS
Drives: His Wife Crazy
Drilled rotors come in a big range of quality.
Poor quality drilled rotors can be down right dangerous,
High Quality drilled rotors are much more reliable, but are not as durable as slotted.
If you are looking for looks over performance, with no track time then drilled rotors might be ok providing they are high quality.
If you are looking for performance, and/or have track time in the future, then you will want slotted.
We offer a number of Quality Packages that not only save you money, but will allow you to choose what the best options are as well as any other related items that you might like. If you would like me to provide you with a link to our brake packages for your car let me know.
Rob@WretchedMS is offline   Reply With Quote
Old 03-05-2015, 05:41 PM   #14
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Beside the "cool" factory these slotted or drilled rotors provide is there any proof of increased performance on the 5th Gen Camaro?
Mods:
