Old 03-03-2015, 07:05 PM   #1
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Look what I got
Got these off Amazon for less then $50 bucks[IMG][/IMG]
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 03-03-2015, 10:43 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What do they fit????
Old 03-04-2015, 10:58 PM   #3
tbss1
tbss1's Avatar
They fit my 2010 Camaro SS. I bought it for the bracket, the bushings were a little bigger then the bars. The brackets that came with the after market bars bent. I used the poly bushings that came with the bars, They are a perfect fit. These brackets are $99 a pair, I was searching on Amazon and found these for $21.xx for the pair. I bought two pairs for $43.22 with free shipping.
