Old 03-04-2015, 05:59 PM   #1
Scott@Bjorn3D
What PSI are you running your Pilot Super Sports at?
Having my tires put on this coming Monday and do not know if I should go with the stock SS 36PSI or do these work better with something else?
Scott@Bjorn3D is offline   Reply With Quote
Old 03-04-2015, 06:05 PM   #2
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
What size tire? I have the 285/35-20 on all four and on the street run 32 pounds like the 1LE. Found 36 was a bit too hard.
bannonm is offline   Reply With Quote
Old 03-04-2015, 06:31 PM   #3
Scott@Bjorn3D
Same size you have running on 10" rim. Think I might try 34 pounds since my BCM module complains at 32.
Old 03-04-2015, 06:33 PM   #4
bannonm
bannonm's Avatar
Never had that issue even at 26 pounds starting off at the track. Maybe that's a change in the later models.
Old 03-04-2015, 09:27 PM   #5
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I was running mine at 35 to 36. Now backed them off to 34 and 32 to see how the ride is. I run 34/33 settings for auto x
VR Baron is offline   Reply With Quote
