Old 03-05-2015, 10:23 PM   #1
Buckstadler
Drives: 2013 ZL1 White/Carbon fiber Vin#658
Changing RPM shift point's?
Has anyone changed the RPM shift point from 6300? If so what would give the most Preformance gains? I have an Automatic.
Buckstadler is offline   Reply With Quote
Old 03-05-2015, 11:21 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Are you talking about the HUD?
Mods:
Old 03-06-2015, 09:46 AM   #3
Buckstadler
I'm not sure what the technical term for it is. JDP mentioned they have rant set up shifting closer to 7000 red line vs the 6300.
Old 03-06-2015, 09:50 AM   #4
Buckstadler
Don't want to hurt my motor. I've always thought a higher shift point at maybe 4th or 5th gear would pick up better times?
Old 03-06-2015, 10:47 AM   #5
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Sounds like you just want to raise your rev limiter, mine is increased by 400 to 6700 rpm now. It just allows you to stay in the lower gears a bit longer thus when you shift your at a slightly higher RPM after the shift.
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 03-06-2015, 10:51 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
I believe the only way to do this is through a tune correct?
Mods:
Old 03-06-2015, 11:42 AM   #7
G Money
G Money's Avatar
Drives: 2013 ZL1, 2016 Denali HD
Yes
LSX 427, Twin Precision Turbo's, 64/66. Nitrous Outlet System. Pro EFI Engine Management Systems. Vengeance Racing Built......
G Money is offline   Reply With Quote
Old 03-06-2015, 12:35 PM   #8
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
How much is too much?
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 03-06-2015, 01:18 PM   #9
Whos_Drivin
Drives: '12 Camaro ZL1, '16 Silverado Z71
It all depends on your mods. If you've added a pulley you'll also have to worry about the SC rpms and fuel depending on injectors/fuel pump.
Whos_Drivin is offline   Reply With Quote
Old 03-06-2015, 05:45 PM   #10
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Stock motor no cai, hi flow cats only.
Old 03-06-2015, 06:40 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
I believe you can set a shift point warning with a DashLogic unit!
Mods:
Old 03-06-2015, 09:55 PM   #12
JamesZL1
JamesZL1's Avatar
Drives: 2013 ZL1 A6 Camaro, 2015 C7 A6 Z51
The A6 stops making power at about 5900-6000 RPMs. I have a ton of Dyno pulls to show this...The M6's continue to make power up to about 6500 RPM...I don't see any reason to raise the Rev limiter much if any in an A6 honestly.
Roto-Fab CAI, Texas Speed Headers, Texas Speed X-Pipe, Texas Speed LS3-B Blower Cam, Metco 9.10" Crank Pulley, Metco 2.5 Upper Pulley, ID 850 Injectors, LPE Ported Throttle Body, Alky Control Methanol kit, E2 Catch Can, 610HP / 608 Torque.
JamesZL1 is offline   Reply With Quote
Old 03-07-2015, 12:29 PM   #13
Buckstadler
The only reason I was pondering the thought was when I run the 1/4 mile my car hits 6th gear. I was thinking if I could up the rev by 400 or so through 4th and 5th it would take up some of the lag and decrease miy time some.
Old 03-07-2015, 12:38 PM   #14
Mikamaro
MikeNoMaro
Mikamaro's Avatar
What? You hit 6th gear in a 1/4 mile!! Dam what geating do you have? 5.25!
