Old 03-05-2015, 11:58 PM   #1
JASON11SS
Drives: 2011 CAMARO 2SS M6 IBM
PULLEY OPTIONS FOR SLP
What pulleys are you guys running on the SLP TVS2300 blowers. Looking to add boost but I'm not sure what pulley system to use. What is everyone doing for overdrive crank balancers. I've got my SLP system on and love it but it's time to crank things up.
JASON11SS is offline   Reply With Quote
Old 03-06-2015, 06:50 AM   #2
Jared91
Jared91's Avatar
Drives: 2011 Camaro SS/M6
Jre is the only on that has pulleys for the SLP as far as I know. I'm running their 3.4. Looking to bump it up too the 2.8 this sping. As far as go overdrive Cranks I don't believe its nessacerry because the slp has so much Belt wrap vs the other superchargers out. Should be able to go 2.8 with an upgraded tensioner and max out the blower if you wanna push it that far.
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
Jared91 is offline   Reply With Quote
Old 03-06-2015, 09:54 AM   #3
JASON11SS
Awesome, that's exactly what i was looking to hear. You are making some solid power with the 3.4 already. Damn.
Old 03-06-2015, 11:18 AM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
METCO sells pullies for the SLP units.
Tampa Tuning is offline   Reply With Quote
Old 03-06-2015, 02:29 PM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Thank you for the referral, Yes it is true we have a full line of pulleys for the New style and old style SLP superchargers.
New style 2.8-3.6
Old style 3.2-3.6
in .2 increments.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-06-2015, 04:00 PM   #6
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Drives: 2011 Forged LS3 Supercharged/Cammed
Jannetty installed my whole setup.
I am also running their 3.4 Pulley.
Here is my list of upgrades so far:
2.3L SLP Supercharger- 9.8lbs Boost
Stainless Works 1 7/8 Coated Headers w/off road pipes
Stainless Works Retro Chambered Catback
Cold Air Inductions Intake W/JRE Scoop
3.4 Supercharger Pulley
ID-850s-96lbs Injectors
TR71x Iridum Spark plugs
Boost a Pump
JRE Tune
567RWHP-526TRQ
JRE Rough idle Blower Cam,ZL1 Fuel pump and electric cutouts up next!
Should make great power!
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL
TRC-SS is offline   Reply With Quote
Old 03-06-2015, 04:02 PM   #7
JANNETTYRACING
Boost a Pump
JRE Tune
567RWHP-526TRQ
ONLY 100 MORE
Old 03-06-2015, 04:15 PM   #8
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Originally Posted by JANNETTYRACING View Post
ONLY 100 MORE
NICE!!!
Old 03-12-2015, 11:30 PM   #9
JASON11SS
That is crazy power for a cam
Old 03-15-2015, 02:44 PM   #10
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
Boost a Pump
JRE Tune
567RWHP-526TRQ
Did you need a super tensioner with the 3.4 pulley installed? I currently running a 3.6 pulley with a zl1 fuel pump, adm fpcm and a msd boost a pump. I want to switch to a 3.4 pulley. I think with all the fuel upgrades i added i should be good with fuel. I think
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 03-15-2015, 03:47 PM   #11
Jared91
Jared91's Avatar
I'm running the 3.4 with the stock tensioner. No upgrade nessacerry to run the 3.4
Old 03-15-2015, 05:51 PM   #12
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
As Jared stated, no you do not. As long as you have the new SLP you are fine. A little different design than the Maggies. You will only need to get a smaller belt!
Old 03-15-2015, 06:04 PM   #13
lincoln361
lincoln361's Avatar
Im sorry. Forgot to mention i have the old jackshaft style tvs2300.
Old 03-15-2015, 06:50 PM   #14
TRC-SS
700RWHP-650TQ
TRC-SS's Avatar
Ah, well I'm sure Ted or tampa tuning will answer that for you then. I'm not 100% on that.
magnacharger, pulley, slp, supercharger, tvs2300
