![]() Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
afe Pfadt Feather Light coil over System Question?
Does anyone know when the afe Pfadt Feather Light coil over system will again be available? They are now located in Corona California. You can see what Camaro & Corvette parts are now currently available at www.pfadtracing.com.
All The Best, Orange 2010 Camaro |
![]() ![]() ![]() Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
You can send AFE a PM directly and ask them. They are somewhere on this board.
Post up what you discover.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
Drives: His Wife Crazy Join Date: Jan 2008
I don't have any info on that, but if i hear anything concrete i'll let you know.
They are supposed to be coming back but are not available yet.
#5 | |
You can also call & talk to Scott as well in customer service, & have your name put on a (first production run) list if desired. You also can see all of the available Camaro & Corvette parts that are currently available at www.pfadtracing.com. All The Best, Orange 2010 Camaro |
#6 |
![]() Drives: Black 2SS/RS M6 Join Date: Mar 2010
How do these stack up compared to the other coilovers options on the market? About the time Pfadt went under was when I had the money to get these. I always liked the quality of their products.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
#7 | |
![]() Drives: Camaro Join Date: Nov 2014
Two we use CIRC system which stands for (Concentric integrated Remote Canister) which basically is like some racing or high performance off road shocks that have a external gas canister that aids in stroke. Ours are internal towards the top, so you don't have to figure out a way to mount the extra canister and make it more of a burden. Helps with low speed bumps and high speed bumps and reaction. On top of that because our shock bodies are longer compared to other companies, our coilovers perform perfectly at stock ride height .Plus our coilovers do reduce overall weight by 34lbs so your suspension has better reaction time as well, which we think is critical in track use or high performance driving. |
#8 |
Do the front coilover use the fe3 10mm or the fe4 12mm endlink bolt?
2010 LS3 2SS/RS M6
#9 |
#10 |
www.1baddogracing.com
Drives: 2010 IOM 2SS/RS Auto Join Date: Apr 2011
Any changes to the drag coilovers and will they still be ready for an early April release?
#11 |
