Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
Zl1 rear bumper conversion thread - info
Can the ones that have done a full rear bumper conversion post info please
I'm looking to do a whole new bumper not just a diffuser install so I need part numbers for everything and I'm not sure what's neccessary. Pictures welcome !!!
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
Any reason why you want to do a whole new bumper and not just buy the ZL1 rear diffuser.
You have two options for adding the ZL1 rear diffuser to your stock rear bumper. Option 1-Remove the bumper and buy the ZL1 diffuser template to cut the slots or Option 2-add the diffuser with out cutting the slots. I used option 2 added the rear diffuser w/ out cutting the slots. Mine has been on since 7/13 no issues. I just cur the tabs off and secured the sides of the diffuser with the rear rock guards the back is secured by the tabs in the bumper. Either method saves you around $700-$800 (ZL1 rear bumper, paint, and bumper absorber) the rear ZL1 diffuser kit will set you back $500.
**FIFTY HBM 2SS VERT** |
Vrrrm.
My SS bumper has chips and scratches maybe I can get it repaired.
So I'll need a absorber,bumper and diffuser ,heat shields, paint
![]() Drives: 2013 2LS SIM Join Date: Aug 2013
I bought the ZL1 diffuser, and used the template to cut the notches in my stock bumper. I don't see any reason to buy a ZL1 bumper, unless you got all that extra money.
Vrrrm.
Ok guys thanks, Im going to get my ss bumper repaired and order the zl1 diffuser tonight.
Should I buy the absorber or no point? I am going to use the tape method instead of cutting.
#6 |
![]() Drives: 2015 Camaro 1LE Join Date: Jul 2010
Please share the parts and part numbers needed for the ZL1 diffuser
#7 |
![]() ![]() ![]() Drives: 2010 Camaro Join Date: Aug 2009
Lots of info here: http://www.camaro5.com/forums/showthread.php?t=190372
And here: http://www.camaro5.com/forums/showthread.php?t=267041 Keep in mind, the conversion only applies to 10-13 model rear bumpers.
#8 |
#TeamBeckyD
No point if you are keeping the stock bumper.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Where can you get the zl1 diffuser? I know i can get it from my dealership but want to see if I can find it for cheaper.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: E92 BMW M3 Join Date: Oct 2012
I got mine from partstaxi.com. I know they were a vendor at one time, but I have not seen them in a while. At the time it was the cheapest I could find. Their kit was missing the little snaps you use to lock in the tabs you cut holes for. If you go the tape route, you wont need them anyway.
I decided to cut the bumper, and it was really easy, just have to get the gusto to do it which is the hard part. I did not have to take the bumper off to do it. One of my favorite mods!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned |
#11 |
#TeamBeckyD
I paid $500 from Maureen from Rodgers Chevrolet all the parts needed for the upgrade.
#12 | |
So it came with the heat shields as well? And is Maureen from Rodgers be able to ship it since I live a pretty far?
#13 |
#TeamBeckyD
Yes the $500 was heat shields and mounting hardware. In the US shipping is Free. Outside of the U.S. Contact her for shipping quote.
#14 | |
Oh wow thats a really good deal then I'll have to call them . Thanks!
