Old 03-07-2015, 12:18 PM   #1
Macaro
Macaro's Avatar
Drives: 2018 Camaro ZL1 1LE
Motul Brake Fluid void's warranty?
Hello,
I'm a recent ZL1 owner and I called a few dealerships today to arrange my first oil change and service. I have already tracked the car twice and I'm excited to track it again in about a month (hurry up and melt snow...) anyway in the service i want to replace the stock brake fluid with Motul because I've read so many positive comments about the fluid.
On one of my dealer calls, the service guy was a bit of a jerk, in any case he told me the price for a brake fluid flush but said he would not use anything but OEM fluid and that using Motul would void my warranty.
Is he right?
Oddly, the second dealer I called didn't refuse to do the service, they only said that I would have to bring the fluid myself.
Bonus second question...what's the difference between Motul 600 and Motul 660? Isn't higher better? Oh, and finally anyone know how much fluid one needs for a complete flush on the (2014) ZL1?
Thank you all,
Macaro is offline   Reply With Quote
Old 03-07-2015, 01:29 PM   #2
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Your dealer is a idoit.
They should only charge around $85 for the full flush if you bring your own fluid.
You only need 3 bottles of Motul to do the flush.
Motul 660 has a lower wet boling point. Thats why we use 600.
I would not fight your dealers....just find one that knows what it's doing.
Mods:
Old 03-07-2015, 02:38 PM   #3
Jeb114
Jeb114's Avatar
Drives: 2021 300
When dealing with a GM service center, they are required by GM to use GM certified parts when working on a car that is still under warranty. If they do sell aftermarket products those parts are certified by GM to be used on a in warranty car. Most dealers use this as a rule of thumb. Some dealers are Performance dealers and have performance products available that are certified for you vehicle. again only if they are working on an in warranty car. If your car is out of warranty they don't care what parts they sell you. The first dealer you spoke do is absolute about this policy. The second dealer will use the fluid as long as you provide it he will not sell it to you. The fluid is fine and I am not saying anything about it. But the catch is in your service records it will say owner supplied brake fluid, if the brakes fail its not GM's responsibility. Look for a Chevy Performance Dealer they know more about these cars than a local Chevy dealer...Good luck with your car!!!
Jeb114 is offline   Reply With Quote
Old 03-07-2015, 03:26 PM   #4
ZL1-V
Drives: 2013 Camaro ZL1
The thing I find hilarious is how many owners of cars do any of us personally know that have had a car fail by changing brake fluid? The same supposed "failure" can occur with normal factory spec'd brake fluid. I agree the performance oriented dealers are much easier to deal with.
ZL1-V is offline   Reply With Quote
Old 03-07-2015, 03:45 PM   #5
ac223mal
Drives: car
From Motul
Motul 600 Extremely high dry boiling point 594F(312C) helps prevent vapor lock and brake fade during hard use, with excellent recovery time. Wet boiling point 401F(205C).
Motul 660 Very high dry boiling point of 617F (325C) and a wet boiling point of 400F
1 degree difference between the two in wet boiling point, but 23 degree difference between the two in dry boiling point.
Is that 1 degree difference really worth the 23 degree difference on the other end?
Just curious, as these are things I am just starting to look at. Never thought I would track my Z, but Ive seen I will never test it capabilities if I don't. So this is all new to me.
ac223mal is offline   Reply With Quote
Old 03-07-2015, 03:48 PM   #6
backeddy
Banned
Drives: 2011 Boxster Spyder (best car ever)
I have boiled both motul products...castrol only for me.
backeddy is offline   Reply With Quote
Old 03-07-2015, 03:50 PM   #7
Macaro
Macaro's Avatar
...Look for a Chevy Performance Dealer they know more about these cars than a local Chevy dealer...
Is there a listing somewhere that tells which dealers are performance dealers and which are not? I do recall reading that to service the ZL1 they had to have a special certification but when I asked both dealers I spoke with today neither really had anything specific to say about that.
Old 03-07-2015, 03:54 PM   #8
z28lt1
Drives: 2014 ZL1
If the customer supplied fluid meets GM's specifications, it is GM's responsibility from an original warranty standpoint. Not necessarily from that individual service (so if the brakes fail under warranty, still covered. If the fluid goes bad quickly, not covered). GM specifies DOT 3 and not to use DOT 5. Dot 4 exceeds DOT 3, so all should be set.
Originally Posted by ac223mal View Post
From Motul
From what I've been repeatedly told, the 660 absorbs moisture quickly. So, you are at the wet numbers much more quickly, and really should change it out every 6 months or less, where as the 600 is still usable for street driving for a while
z28lt1 is offline   Reply With Quote
Old 03-07-2015, 03:59 PM   #9
ac223mal
Drives: car
again curious,
castrol dot 4 brake fluid 311 wet and 509 dry boiling points, why would castrol work better than motul?
Old 03-07-2015, 04:01 PM   #10
ac223mal
Drives: car
Thank you, new question, are you guys replacing break fluid every time you track your car?
Old 03-07-2015, 05:34 PM   #11
Z/28Dan
Z/28Dan's Avatar
Drives: 2023 1SS 1LE Vivid Orange
What warranty are you worried about voiding?
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 03-07-2015, 05:56 PM   #12
Macaro
Macaro's Avatar
The factory warranty...3/36
Old 03-07-2015, 05:59 PM   #13
Retro69
Retro69's Avatar
These dealers are jerks. If they happened to run out of the genuine GM brake fluid when servicing your car they would not hesitate to have their parts runner head down to the local NAPA or whatever parts store and bring back some aftermarket fluid so they can get the job done.
Sent from my iPad using Tapatalk HD
Retro69 is offline   Reply With Quote
Old 03-07-2015, 06:32 PM   #14
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
If you're getting water in your system quickly, you've got other problems.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
