Old 08-29-2009, 09:12 PM   #1
K-Money
Drives: 2010 Camaro 2SS/RS Ordered
Cool How To Fix Door Panel Buzzing/Rattling
If your door(s) is/are buzzing:
  • Remove the rubber "tray" in the middle of the door panel towards the front of the armrest. This is the part you grab to shut the door.
  • Use a 5/32 Hex tool to loosen the bolt 1/2 to 1 full turn
  • Replace the rubber "tray" and you are in business.
I have read a couple of posts about this problem so hopefully this will help a few of you out. A few days after I got my SS, I started noticing a VERY severe buzz coming from the passenger side door. It was so bad that I thought I had blown one of the BA speakers. I thought that was pretty rediculous, honestly, since it was only a few days old and I had not even had the volume above 30.
Thanks to the wonderful sound of the LS3, I have had many trips where I have just shut off the radio so I could listen to the "other stereo". I started noticing that the buzzing continued even then, with the speakers totally unpowered. My girlfriend pointed out that the sound seemed to be coming from even further back, near the center of the door, and if she applied pressure there it would stop. Further tests verified that the speaker was not blown and working fine. Also, though not as bad, I noticed the driver's side door was producing a similar sound.
I had been considering taking it in to the dealership to see if they could do something about it (doubtful) or just taking the whole door panel off myself to see if I could fix it. Before I did that (after pounding the plastic a few times) I noticed that there is a hex screw beneath the small rubber "tray" that is in the armrest of the door, between the part where your arm lays and the door handle. I took a 5/32nd hex tool and tightened that screw as much as I could without feeling like I was causing damage. That didn't help...and it may have even made the problem worse. Then I decided to back the screw out a whole turn and BINGO! That is just enough that the door panel doesn't feel loose, but enough that it doesn't make contact with whatever internals were causing it to buzz. This worked on both doors and after several road (engine, bumps) and garage (BA) tests, the horrible buzzing sound has completely vanished!
I am not making any guarantees this will work on your car, and I am certainly not responsible if you break something, but I think this is about as simple a solution as there can be, so you may want to give it a try if you have the problem.
K-Money is offline   Reply With Quote
Old 08-29-2009, 09:14 PM   #2
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
interesting...thanks for sharing
Old 08-29-2009, 09:42 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
or just take the spare change out of the tray...
j/k... good info..
Old 08-30-2009, 03:12 AM   #4
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
I thought I heard a SLIGHT buzzing from the passenger door. I'll pay a little more attention next time and see if I can pinpoint it.
Old 08-30-2009, 06:44 AM   #5
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
well i'm adding sound deadening materials anyways lol, i'ma have king kong in the trunk lmao
not really, probably just one W7,or my L7.... but it does really improve the music and overall cabin noise
Gentry78 is offline   Reply With Quote
Old 08-31-2009, 06:29 PM   #6
CASTIG 2010SS
Drives: 2010 CGM Camaro SS\RS
Thanks for the great post. It has been bugging the piss out of me since I got my car. Did not want to have to take it in for that but I was just about to. Worked great. Thanks. You earned your name, you are MONEY
CASTIG 2010SS is offline   Reply With Quote
Old 08-31-2009, 10:50 PM   #7
K-Money
Heh, no problem. If it helped one other person, I am happy. :-)
Old 09-13-2009, 09:02 PM   #8
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
I just finally got around to doing this and it worked like a charm! I didn't have the wrench needed so had to wait to go to my parents to grab one. Thanks a ton k-money!
UCF w00t is offline   Reply With Quote
Old 09-16-2009, 05:48 PM   #9
Laserjen
Drives: 2013 Camaro 2SS/RS
I have been noticing buzzing from my passenger door on and off for a week or so now, I too thought it was my speaker (but didn't see how it could be). It was really bad last night driving home from work, but I found this thread last night and tried the fix this morning -- no more buzzing!! Thank you!
Then: 2LT/RS Black/Black auto w/sunroof
Now: 2SS/RS CRT/Black auto w/sunroof
Laserjen is offline   Reply With Quote
Old 09-16-2009, 06:29 PM   #10
K-Money
Hey, I aim to please. I am glad everyone else is having similar success!
Old 09-16-2009, 08:16 PM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
i tried this and didnt work for me, then i pressed my arm up against the armrest and the rattling went away...anyone know how i can stop that rattle?
Oh and when i have my music on, the rear panel that houses the rear speaker rattles like no tommorow, its unbelievable how much it rattles....i wonder if there is any other way of getting that to stop other then sound deadening
Old 09-16-2009, 11:28 PM   #12
K-Money
Don't know on the rear panel. If you loosen the bolt in the door a little more, you might have some luck. I was having the same problem and pressing against the door made it go away, that's why I initially tightened the bolt (which didn't help). I had to loosen the passenger side much more than the driver's to make it stop.
Old 09-16-2009, 11:39 PM   #13
LSP2010
IM A GURL
LSP2010's Avatar
Drives: 2010/2SS
j/k... good info..
How u know that happen to me lol
1100, Preliminary order accepted - 13oct08
2000, Order accepted by GM ----- n/a
3000, Order acc. by P.R---------- n/a
3100, Order available to sequence- n/a
3300, Order sch. for production--- 21may09
3400, Order broadcast------------ 28may09
3800, Order produced ------------ 2jun09(2G1FT1EW8A9114199)
4000, Available to ship
4200, Shipped--------------------9june09
ITS HERE 18JUNE09
LSP2010 is offline   Reply With Quote
Old 09-16-2009, 11:49 PM   #14
K-Money
Hey, UCF w00t, glad it helped. I want to personally THANK YOU for the work you did on the spasticsquirrel database. I, like many people, didn't get much info out of my dealer during the wait and you have no idea how much joy I had the day my VIN showed up in the database. Of course, then I got stuck in Warehouse 13 for 2 months, but your site was a huge help, nonetheless. THANK YOU!
A Tranny/AFM Fix Has to be Coming..... Toons 5th Gen Camaro SS LS LT General Discussions 19 06-05-2009 11:41 PM
How to fix my wheels? Rocks RS General Automotive + Other Cars Discussion 5 05-01-2009 10:59 AM
Dealer Inspections: What do they do, and what do they fix? Horror Story 2Muchmark 5th Gen Camaro SS LS LT General Discussions 1 04-11-2009 03:48 PM
What do you use to fix scratches? MRK III Z28 General Automotive + Other Cars Discussion 7 01-03-2009 03:12 AM
Anyone know how to fix this? TAG UR IT Off-topic Discussions 19 03-12-2007 01:43 AM
