Old 03-09-2015, 04:04 PM   #1
45THanniversarySS
Builder of fast cars
45THanniversarySS's Avatar
Drives: 2012 2SS 45TH Anniverary Edition
air bag sensor
So im not sure hot tofigure out which air bag sensor is kicking a message on my display...2012 ss and its beenthis way for a while...got rain in the car one day and had this issue since...well i figured removing the bad circuit might make it go away that way id know which sensor to replace...so i removed the passenger seat (thought it was that one because im having issues with passenger airbag light on mirror) well i unplugged and removed the seat and clicked the key forward to still find the same issue...so i removed the driver seat and clicked the key...still have warning on display...can anyone pitch me some ideas before i lose my mind...i dont wanna start replacing every sensor just to find that 1
45THanniversarySS is offline   Reply With Quote
Old 03-09-2015, 05:38 PM   #2
Reineke
Drives: 2010 SW Camaro 2SS RS 6M
Pay to get it scanned. The dealer if you have to. Better than losing your mind or shot-gunning parts. Some mechanics in my area offer free scanning, so it may pay to call around.
Reineke is offline   Reply With Quote
Old 03-10-2015, 08:35 PM   #3
thiggin2
thiggin2's Avatar
Drives: 05/07 Chevy's
It doesn't work like that. The only way to make the light go out is to fix it. Pulling different components will only cause more codes to set. So now you have more codes set then what was first there. You will need to have the codes cleared and see what resets.
thiggin2 is offline   Reply With Quote
Old 03-17-2015, 01:40 PM   #4
Char1ieone
Fear the Red Bow Tie
Char1ieone's Avatar
Drives: 2010 Black Camaro 2SS/RS LS3
Do you happen to know whether it is standard to be charge to re-zero the airbags at a dealership?
Char1ieone is offline   Reply With Quote
Old 03-17-2015, 05:20 PM   #5
lawdog
Drives: 2010 SSII w RS & Sunroof Yellow
Location: West Suburbs of Chicago, in a Courthouse Somewhere
There is a tendency with GM to look first at the plug under the passenger seat and see if it got upset, possibly by someone vacuuming under the seat, sometimes the wire needs to be pushed back into the connector firmly and the light will go off after you recycle the key a few times. I have had that issue in a few GM cars now. On some other GM's it's a Blue Connector, not sure what color it is on the Camaro.
lawdog is offline   Reply With Quote
Old 03-17-2015, 06:00 PM   #6
thiggin2
thiggin2's Avatar
Unless the service adviser does it for free normally if a service order is made then there is a charge. Some techs may not charge but that's up to them as almost all techs are flat rate paid.
