Old 03-10-2015, 10:57 PM   #1
Rumbumbees$ponsor
Rumbumbees$ponsor's Avatar
Drives: Autobot
2010 to newer suspension
Can someone explain parts needed to do the conversion from 2010 to current model?
I guess the Fe6 is what im talking about..
gm parts and names front and rear..
Rumbumbees$ponsor is offline   Reply With Quote
Old 03-10-2015, 11:09 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
i can't post a link, but if you look at the Camaro FE3 Suspension Packages on my website there is a Camaro 1LE Track Pack - For FE3/FE4 Cars that includes everything except the rear control arms (that are also on the site in another place and the part number is listed in the package)
Rob@WretchedMS is offline   Reply With Quote
Old 03-11-2015, 01:42 AM   #3
forklord
forklord's Avatar
Drives: 2010 2SS
did you sell your blower yet? i did. took a bit of a loss but im definitely going to be track ready soon i assume thats what youre aiming at too?
I didn't know there was an "FE6?" i did the fe4 conversion from fe3 which is 2012+ SS in BMR parts which, handling wise, is just stiffer sways, struts and the rear sway sits outside the struts which require a bracket or the newer control arms i think. that longer rear sway in itself is a huge upgrade.
@Rob fixed your link for you https://www.wretched.co/camaro/ss/su...amaro-packages
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 03-11-2015, 06:56 AM   #4
Mike_G
Drives: 2010 2SS/RS
FE6 is the Z28 suspension I believe. FE5 is 1LE, FE4 is the upgraded rear sway/ endlinks and control arms in the 2012+. Are you looking to do FE4 or FE6?
Mike_G is offline   Reply With Quote
Old 03-11-2015, 08:11 AM   #5
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
You can order the Pfadt ZL-Spec kit.
It comes with everything you need: Front + Rear sway bars, 2012+ control arms, end links.
Some vendors still have this in stock. It makes a HUGE difference in handling that can be immediately felt and enjoyed.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-11-2015, 12:07 PM   #6
Rumbumbees$ponsor
Drives: Autobot
I was told the FE6 is 2015 for ss 1le, I just want to upgrade to the best parts since I have a 2010.
What parts are different on my 2010 vs the 2015 SS 1le, I know the sway bars are.. and I kinda know in the back there is a piece that you replace on each side for the newer endlinks?
What about front is there any difference in my 2010 ss vs 2015 1le?
Can some one list the name and part number to switch over to 2015?
thanks
Old 03-11-2015, 01:04 PM   #7
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
http://www.camaro5.com/forums/showthread.php?t=398746
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 03-11-2015, 01:16 PM   #8
Rob@WretchedMS
Thanks Bull, i should have done that myself, lol
Old 03-11-2015, 01:40 PM   #9
Rumbumbees$ponsor
Drives: Autobot
Question 1 is this correct?
So by looking at that the lower rear control arms, the rear sway bar and endlinks, and as for the front, the sway bar would just have a larger hole and the end links would be thicker and use be 12mm instead of 10mm?
question 2.. If I had the rear sway bar from a 2015 1le and end links and the rear lower control arms would it be worth upgrading later to BMR or Detroit?
Old 03-11-2015, 01:58 PM   #10
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Correct
The 1LE bars are good, but going to an adjustable setup will allow you to dial in the suspension to your wheel/tire combo and your driving style as well as offer more roll resistance than what the OEM 1LE bars can provide.
The BMR sway bars are good, but the DSE bars are a stiffer setup and so far the most well balanced setup we've tried to date.
Best regards,
Tyler
888-308-6007
Old 03-11-2015, 02:17 PM   #11
Rumbumbees$ponsor
Drives: Autobot
Well Im buying a complete 1le rear piece, I really just wanted the differential but it comes with well you can see (shocks, swaybar, rear end, axles, endlinks, pretty much everything)..
the best price I found on the 1le diff was 1362.00 plus 65.00 for ship I can get the whole setup for 1400.00 plus ship..
So I didn't know if I should get differential and bmr or Detroit parts or get this whole asm..
Old 03-11-2015, 02:44 PM   #12
JDP Sales
JDP Sales's Avatar
Sweet deal! I'd leave the differential bushings alone, but while you have the cradle out, I'd upgrade the upper control arm bushings and cradle bushings.
The factory lower control arms are actually pretty decent, it's the trailing arms and toe links that are prone to deflection.
Best regards,
Tyler
888-308-6007
Old 03-11-2015, 03:10 PM   #13
Rumbumbees$ponsor
Drives: Autobot
ok send me a link for bushings
Old 03-11-2015, 05:20 PM   #14
JDP Sales
JDP Sales's Avatar
Just replied to your PM. Let me know if you have any questions and I'll be happy to assist you further.
Best regards,
Tyler
888-308-6007
