Old 03-11-2015, 11:04 PM   #1
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
1LE rear differential on regular SS
Will the 1le diff bolt right up in place of my SS manual trans rear diff?
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 03-11-2015, 11:45 PM   #2
Bo White
Bo White's Avatar
Yep
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-11-2015, 11:47 PM   #3
bionick
bionick's Avatar
Originally Posted by Bo White View Post
Yep
Sweet thanks.
Was originally planning on doing the 3.91 ring and pinion install (at a shop) but it seems like it would be a better deal to buy a low mile 1le diff, getting it swapped out and just selling my current diff.
Do you know if the 1Le axles will bolt right up or do I need the hubs and stuff too?
Old 03-12-2015, 08:01 AM   #4
Bo White
Bo White's Avatar
Yep
It's simpler for the guy in the driveway to swap diffs than gears for sure.
Totalled:
Old 03-12-2015, 11:28 AM   #5
bionick
bionick's Avatar
Yep
What about the 2014 1LE diff?
I'm possibly buying one. You are saying that will bolt right up with no additional parts?
Thanks
Old 04-20-2015, 06:53 PM   #6
Bell
Bzell
Bell's Avatar
Drives: 2010 Camaro SS
Where did you purchase a 1le diff from? I'm looking to do the same mod.
Bell is offline   Reply With Quote
Old 09-29-2015, 09:52 AM   #7
Inferno 10
Drives: 2010 Camaro 2ss/rs
Hello I have 2010 2ss/rs. Does anyone know if a 2014 1le 391 diff will swap out with my 345 diff using my stock 2010 axles and hardware ?
Inferno 10 is offline   Reply With Quote
Old 09-29-2015, 10:19 AM   #8
bct10985
Drives: 2010 2SS LS3, 2013 duramax
As far as i know they are the same thing just different gears
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 09-29-2015, 11:28 AM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
A 1LE diff is no different than the diff on any other SS except that it has 3.91 gears inside. Regardless of year it will bolt right up to a LS3 and L99 SS without any additional changes. However, the dealership will not calibrate your speedo and GM will not warranty it. If you want that then you have to do the gear swap into your diff.
Old 09-29-2015, 05:12 PM   #10
Inferno 10
Ok thanks for the info. I didn't want to get my diff out and go to put the 1le diff in and find out that my axles and mounts and all wouldn't fit it ! That would ruin a weekend.
Old 09-30-2015, 01:14 PM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
An only difference in the 1LE axles is that the outer CV joint is larger same hubs/and spline count. Now the true 1LE/ZL1 hub bearings themselves are bigger but still works with SS axles.
Old 10-28-2015, 09:40 AM   #12
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
Where are you guys finding the Diffs?
Explit Player is offline   Reply With Quote
Old 10-28-2015, 10:00 AM   #13
Apex Motorsports
We order them directly from GM.
Old 10-28-2015, 10:01 AM   #14
Explit Player
IG @Brian_ _Self
Do you know off the top of your head what they run?
Sent from my VS986 using Tapatalk
