![]() Drives: 2012 Camaro v6 LFX Join Date: May 2013
American Race Headers down pipe LFX engine
I'm having a problem with the pypes mid muffler cat back system and down pipes, I have been too a couple exhaust shops and have figured out the problem! The said problem is called kick back?!? The shop says it is because my exhaust flow is to open allowing too much free flow and vibrating the mufflers from the inside. They said I need to put the cats back on to create more back pressure to eliminate the unwanted sound. I have also read that there is a possibility of tuning this out any input? I don't want to put the cats back on and was wondering if anyone knows of a way to create more back pressure without using the cats maybe special mufflers or resonators, or if anyone knows how to tune this out if that is actually possible.
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
... What problem are you having the with exhaust system in the first place? Start there. That wasn't clearly stated other than what the exhaust shop told you.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
Not that I'm saying this to compare the two, but I put on an aftermarket exhaust on my bike years ago. The new pipes are just pipes, no baffles and when I wrote it for the first time I felt a power loss in the acceleration. When I researched it, I found something about how the bike doesn't have backpressure giving it more power this the loss of said power
Problem is as follows; loud metallic rattle noise from inside mufflers.
Exhaust is as previously stated; Pypes mid muffle cat back exhaust with ARH down pipes cat delete |
![]() Drives: 1987 IROC-Z 5.7L 2016 1SS M6 NGM Join Date: Jan 2015
Remove the muffler!
MagnaFlow makes some decent mufflers that usually have a deeper tone.
#6 |
Is there anything I can put on before the x pipe that would increase back pressure? Or am I better off with putting the cats back on and calling it a day?
#7 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
If the exhaust is done right...you can never have too much "free flow"..
The whole point of exhaust in the aftermarket is to speed up exhaust velocity, which increases the scavenging effect. If youre having issues its because something you have added has slowed down exhaust velocity allowing it to cool quicker and slow the flow Quote:
If you have an issue with a metallic sound, which is the same thing ford had on the new mustang v8 with the overhead cams and the reason RTR developed the new mufflers for their package...use quality mufflers to absorb the sound. All cars with the direct injection and overhead cams, while more efficient and powerful, tend to have a more metallic outcome when less sound absorbing is around. exhaust works the same way in a 4 cycle engine. Suck squish bang blow. This is pretty much universal whether its a 4 cylinder or a 12 cylinder if not more. Maganflow put this article out years ago...great read amd youll see all the myths people still have about engines needing backpressure and more. Also theres an article that has been around about cats and hi flow cats vs stock. Its a good read. http://store.uucmotorwerks.com/articles/catless.htm In your case my advice is to simply look for some straight thru quality mufflers. Maganflow Borla or Corsa are def of quality. They cost more but you get what you pay for.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant Last edited by PolynesianPowerhouse; 03-14-2015 at 08:47 PM. |
#8 |
![]() Drives: 2015 Camaro LS M6 Join Date: Sep 2014
Add back pressure in a 4-stroke? Sounds counter intuitive.
Guess I should add 2-strokes do need a small amount of beack pressure, the split second the intake and exhaust ports are exposed. |
