View Poll Results: Does the Brembo Brakes on your Camaro squeal?
Yes 42 60.87%
No 27 39.13%
Voters: 69. You may not vote on this poll
Old 03-13-2015, 11:38 PM   #1
z28guy30
z28guy30's Avatar
Drives: 2016 camaro 1ss
Do your breaks squeal on your Camaro SS?
I just bought a 2011 Camaro 2SS, and my brakes are squealing everytime I slow down to stop. I understand they are high performance Brembo Brakes, so some noise may be normal due to the metallic pads but it is pretty embarassing when coming to a stop. Does everyone else have this issue with their car?
z28guy30 is offline   Reply With Quote
Old 03-13-2015, 11:49 PM   #2
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Have you inspected the brakes yet? I would not judge your cars symptoms by whether or not another cars brakes squeal. All cars brakes could squeal, heck my Z/28 was squealing this evening when I went out for pizza. I would have the brakes inspected for rotor wear, type of pads installed, anti/rattle squeak clips or shims for the pads, and that the calipers are installed with proper bolt torque. The sound your hearing is the vibration of the rotors, (similar to a wet finger around crystal wine glass).
Zslash28 is offline   Reply With Quote
Old 03-13-2015, 11:50 PM   #3
The_Blur
Moderator
The_Blur's Avatar
Mine due. A lot of cars do that as the brakes wear. I'm going to have mine inspected in the near future.
warn 145:159 ban
Old 03-14-2015, 01:02 AM   #4
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
When they get hot, ever since new. But only a tiny bit, not enough to be embarrassing or fingernails on chalkboard.
OrangeVert is offline   Reply With Quote
Old 03-14-2015, 01:03 AM   #5
Bad@ssCamaro
BeckyD Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
Check your brake pads to make sure they don't need replacing.
Old 03-14-2015, 01:14 AM   #6
Kawirocket674
Drives: 2013 Camaro SS
Brembos make some noise under light application.
Kawirocket674 is offline   Reply With Quote
Old 03-14-2015, 01:19 AM   #7
enzia35
Drives: '16 Garnet Red 1SS
First thing in the morning. But v6 here.
'16 Camaro 1SS
'18 Miata GT
Gone: '01 Camaro, '14 Camaro, '90 Miata
enzia35 is offline   Reply With Quote
Old 03-14-2015, 01:33 AM   #8
fpdsniper
fpdsniper's Avatar
Drives: 2011 Synergy Green 2SS/RS
A couple things here, you indicate that you just bought it. Do you know if the previous owner or dealership may have just put new brakes on? If so, what type pad material was used? Metallic brake pads are much more prone to squealing. If semi-metallic or ceramic, were the broken in with some hard braking stops to wear them in? Just some ideas here.
2011 Camaro 2SS/RS Synergy Green LS3/M6
Skip Shift Eliminator
Vitesse Throttle Controller
2008 Toyota Tundra Double Cab SR5/TRD
Independent Amsoil Dealer
fpdsniper is offline   Reply With Quote
Old 03-14-2015, 01:43 AM   #9
smarbrit
Drives: 2012 Camaro 2SS/RS IOM
Mine do and always have. My rotors warped at less than 10k kms, had them machined, but the squealing didn't change. I asked this question as well before, I understand that they can glaze and hard breaking will help to remove the glazing. Not a very technical answer but is what I have been told. Car is due for service and time to check the brakes as I'm at 64k kms.
smarbrit is offline   Reply With Quote
Old 03-14-2015, 01:50 AM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The Camaro comes with metallic brake pads and metallic pads will squeal a little on light applications. Check the pads first to see if they are worn and need replacing, if they are good then do a bed in procedure and your squeal should go away for a couple months.
Old 03-14-2015, 06:02 AM   #11
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Mine make a little "squeal" (if you want to call it that) sometimes, after the car has been sitting for a while - especially if the rotors were wet when I parked it, or it is very humid. If you look closely, you can see a light coating of rust that forms on the rotor.
I have about a 1/4 mile between my driveway and a stop sign at the end of the street. If I just apply the brakes a little firmly as I approach the stop, it rubs that rust off and no more squeal from then on - until the next time. If no moisture is on the rotors when I park it, there is no squeal when I drive it after sitting.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 03-14-2015, 07:08 AM   #12
Smokin19
Drives: 19' ZL1 A10, w/pdr
A lot of road grime will sometimes gum up the pads and coat the rotors. I have always cleaned my rotors with rubbing alcohol on my Harley when this happens (Brembos also) and the squeal goes away. Not saying this will cure your issue.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/Gesi cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
Smokin19 is offline   Reply With Quote
Old 03-14-2015, 07:57 AM   #13
snarky
ultracrepidarianism
snarky's Avatar
Drives: '14 1SS/RS/1LE/NPP '18 Accord Sport
no.
snarky is offline   Reply With Quote
Old 03-14-2015, 10:37 AM   #14
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
Mine don't now. They did with the stock brembo's but since I have done the 6 piston CTS-V conversion, they are quiet as can be.
CHMSC is offline   Reply With Quote
