Old 08-30-2009, 11:23 AM   #1
Speedy One
Drives: 2010 Camaro SS/RS
HELP: O2 SENSOR LOCATION
I'm installing some headers and the instuctions say to disconnect the o2 sensor from the main harness. My 68 & 69 GTO'S don't have 02 sensors. Can anyone help me with locating the 02 sensor. I guess I'm to old to know. know.
Speedy One
Speedy One is offline   Reply With Quote
Old 08-30-2009, 12:21 PM   #2
felixbed
Drives: 2010 victory red ss
There are two sensors on each side. One connection is under the car along the tranny, the other is up behind the block on each side. (Just follow that grey wrap wire coming up into the engine bay just below the manifold/cat connection. I'm looking into disconnect methods myself for my DT shorty headers.
felixbed is offline   Reply With Quote
Old 08-30-2009, 01:19 PM   #3
Speedy One
Felixbed'
I found the sensors thx, I'm still trying to figure out how to unlug the ones mounted on the tranny. It looks like it has some type of plastic security type zip tie or something through the plug to keep a guy from unplugging it. I'm installing DT shorty's also. Let me know if you figure out thr security tie @ the tranny plugs.
Speedy One
Old 08-30-2009, 01:42 PM   #4
felixbed
I think you have to squeeze together to slide it out. Those on the block what did/are you going to do with those?
Old 08-30-2009, 01:51 PM   #5
Speedy One
Those come apart faily easy. There is a green plastic tie, just pull on the tab and it will come out then you can pull the plug apart. Still haven't got the ones on the tranny, I can't get the plastic tie out to unplug them, may have to cut it.
Old 08-30-2009, 02:49 PM   #6
felixbed
thanksfor the tip. Won'T needle nose close up that clip on the lower sensors? I'm planning on Friday when I can have my son help me get the cat/manifold out. Should make for a nice sound and a bit more get up and go.
Old 08-30-2009, 04:30 PM   #7
Speedy One
Got the sensors @ the tranny, the needle nose worked, a liitle akward though, the drivers side is harded to get to though. The 02 sensor on the block on the passanger side was a bugger, I think they installed it before the motor went in because the tab was facing the inside of the block, just had to pull on it very hard with my fingers, it came after the 10th try.
Old 08-30-2009, 04:57 PM   #8
felixbed
Good luck with the rest of the install. I can't wait to get those headers in. Need to make sure that I have a whole day to work on it just incase of any set backs.
Old 08-30-2009, 08:46 PM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Just a question but why are you removing them from the main harness? You only need to disconnect them from exhaust.
Old 08-31-2009, 09:56 AM   #10
Speedy One
Draco: It dosen't look like you can remove them from the exhaust it looks like the wires coming from the sensors mounted on the back of the block are pressed in. The other set you have to unplug at the tranny, they are threaded into the exhaust but if you don't disconnect the plug it would twist the wires while you tried to unthread them.
