Old 03-16-2015, 03:39 PM   #1
cammotion perf
cammotion perf's Avatar
Drives: cam tech
Cam Cores: 5150, 8660, 8620. What is the difference?
5150, 8660 & 8620 cam cores, what is the difference and which is best? We will break it down with this simple explanation.
5150 Induction Hardened Chromium
5150 is the standard camshaft that most all of our competitors sell. This alloy is induction hardened. While it is not the best available, it is perfectly fine for most applications if proper care is taken to finish the lobes properly.
8660 Induction Hardened Nickel-Chromium-Molybdenum
8660 cam cores have a superior alloy to the 5150 and are induction hardened. This is a step up over the 5150 cam cores.
8620 Carburized Nickel-Chromium-Molybdenum
Our 8620 camshafts are made of a superior alloy to the 5150 and these cores also endure a more involved oven hardening process. This hardening process creates more durable wear surfaces on the lobes while maintaining the desirable ductility characteristics of the the 8620 alloy. The final product is a camshaft that is stronger with a more durable wear surface. Our 8620 cams are a superior product.
Because we know that, for some enthusiasts, pricing is a major factor in choosing parts, we now offer all 3 cam core options. This is an extension of our commitment to make sure that our LS customers can get exactly what they want in a camshaft.
Our pricing for these 3 different cam core choices is as follows:
5150 $399.00
8660 $425.00
8620 $449.00
cammotion perf is offline   Reply With Quote
Old 03-16-2015, 11:33 PM   #2
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
JCunningham is offline   Reply With Quote
Old 03-17-2015, 09:47 AM   #3
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
For just $50, its a no-brainer that you should go with the 8660 material. Only for the longevity preventing the need to go back in a year sooner and replace the cam made with a softer alloy.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
Old 03-17-2015, 09:53 AM   #4
JCunningham
Drives: 2017 2SS M6
+ better quality control
Old 03-17-2015, 10:38 AM   #5
LOBBS
LOBBS's Avatar
Drives: 2010 Camaro 2SS/RS
The upgrade to 8620 is a small price to pay for big longevity.
LOBBS is offline   Reply With Quote
Old 03-17-2015, 09:01 PM   #6
Verbatim
Drives: '18 2SS 1LE HBM
FWIW stock GM cams are a 5150 material. The 5150 should be a harder alloy than the 8620 given the right heat treatment, but the surface carburization of the 8620 is what gives it the improved wear resistance.
All 3 look like great choices, props to Cam Motion for providing us with more options!
Verbatim is offline   Reply With Quote
5150, 8620, 8660, cam cores, cam motion
