Installing suspension this weekend - what else should I add?
I have the BMR front and rear sways (sb039), oem end links and lower control arms.
Before I get installed im wondering what other things should I look at "while I'm there". 2010 SS that will be primarily used to drive around country roads on road trips and maybe road corse tacked once per year. Not looking for anything I won't really feel, but figured while I'm doing all this if there are some other components I should add while I'm at it.. Trailing arms and toe links?
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
Drives: His Wife Crazy Join Date: Jan 2008
you'll need end links that have 12mm studs on one end and 10mm studs on the other to connect the front swaybar properly.
which lower arms did you get? |
I got the 2012 end links with the 12mm as you mentioned
then you will need a 12mm drill bit to drill out the front struts.
Which lower arms did you get? |
Yeah I will. And BMR
#6 |
right, but they make different ones and that makes a difference on my recommendations for you.
#7 |
Nothing else is really necessary, but you could do toe links to take advantage of only having to align once. Everything else would just be icing on the cake.
Best regards, Tyler 888-308-6007 |
#8 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
With the LCA's off, it would be an easy time to add springs/coilovers.
trailing arms and toe rods can be done at the same time too, but there really isn't any duplicate work other than the jackstands and taking the wheels off. I also did the front radius arm bushing inserts and steering rack bushing at the same time as the fronts.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
#9 |
Should of mentioned I also have springs already installed. Thanks for all the help! Maybe I'll take a look at some toe links!
#10 |
PM Sent Tyler
#11 |
if you bought the lower arms that are not adjustable then i'd say it's a good time to install the eccentrics that allow more adjustment than stock.
if you are going to get toe links, then i'd go and do the trailing arms too. The cradle will need to be dropped to do the left side toe link, so that would make it a good time to do the sub frame bushings, Also doing the bushing at the rear of the trailing arm in the knuckles would be a good idea. |
#12 |
2010 2SS/RS M6
^^^ I only had to loosen the bolts on the subframe for the toe links, not fully drop it.
#13 |
ya, it doesn't need to come completely out of the car, but it needs to be dropped on the left side (with the left bolts removed and the right bolts loosened), but if you are going to go that far, and you have to remove the bolts for the toe links anyhow, why not replace them with the more adjustable eccentrics, and your half way there for the Subframe Bushings.
