Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
Help- rear strut not lining up with lower arm
What did I do wrong?
The car was lowered 1 inch prior with coilovers now I'm trying to put factory shocks back. Did I put them together wrong seems way off to me.. ![]()
![]() Last edited by revived; 03-17-2015 at 05:35 PM. |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
I don't tighten up the top 4 bolts until I have the bottom attached. You have to disconnect the LCA from the knuckle to drop it down to allow space for the strut/spring assembly to swing into place.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
![]() Drives: 2010 2SS/RS Join Date: Jul 2014
yup, undo the bolts at the top. Bolt the bottom in first but do nott tighten it down. Ypou can then jack up the arm a bit to bet the top bolts started if needed.
Vrrrm.
Figured it out, thanks though!!!!!
That's exacttly what I ended up foing
