03-18-2015, 09:33 AM | #1 |
Drives: none yet Join Date: Dec 2014
Z28 Aero Kit on ZL1
Has anyone done this yet? Looking for pics if someone has. Looks like the wheel arches or whatever they are called are matched up to the side skirts. Can you even buy the aero kit yet?
03-18-2015, 09:51 AM | #2 |
KaBoom1701
Why mess with perfection?
Mods:
03-18-2015, 10:20 AM | #3 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
I think that would be the ugliest mod if it were done. I already have some issues with it on the Z/28. It would be the worst downgrade for the ZL1 IMO; Attempting to imitate another model instead of appreciating its own greatness.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
03-18-2015, 12:47 PM | #4 |
C.O.T.W. 10-27-2014
I believe stevezl1 is doing it. The look of the z28, with the zl1 motor and suspension i think will look insane. cant wait to see put together.
03-18-2015, 05:15 PM | #5 | |
COTW 12.15.14
Drives: 2015 Camaro ZL/8 Join Date: Aug 2014
This is what I am going to call "The Car GM should have built"
COTW 12.15.14 Follow my build thread: http://www.camaro5.com/forums/showthread.php?t=384682 AND check me out on Instagram @ZL8CAMARO
03-20-2015, 05:55 PM | #6 | |
Drives: 2013 ZL1 Triple Black, 2015 2LT/RS Join Date: Apr 2012
You and KaBoom have expressed exactly what I think as well. Well said, both of you. |
03-20-2015, 07:36 PM | #7 | |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
Might be cool to keep the ZL1 wheels and have them widened and spaced. Then run an even wider tire package with the added width from the fender skirts. |
03-20-2015, 07:58 PM | #8 |
COTW 12.15.14
I am going with Custom Niche Momoblock wheels.
03-21-2015, 09:58 AM | #9 |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
Damn those are some sexy ass wheels!!!! I was looking those online but the pics don't do them justice. Post up pics once installed please!!!!
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
03-21-2015, 10:52 AM | #10 |
COTW 12.15.14
Thanks for the complement. Should be getting back to work on her in a few weeks. The crap weather in NY just does not want to give. But once on the way I will post plenty of photos on my build thread.
03-21-2015, 11:12 AM | #11 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
03-21-2015, 12:23 PM | #12 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Just curious what size those rims are. There are very few top tier tire choices in a 20" rim right now. Pretty much have to go with 19"s or less if you want a race grade tire.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
