Old 03-18-2015, 07:46 PM   #1
camarossdusk
whippled 5th gen
Drives: 2013 camaro ss
driveshaft safety loop
what's the difference, I see that metco one looks different than bmr one. trying to get my car ready to run at the track next month, any good helmet recommendations.
Whipple running 13 lbs of boost, Innovators west 8 rib with 10 percent over drive crankshaft pulley. Fore level 2 Dual pump fuel system, with duel TI auto fuel pumps, ID 1300 fuel injectors, tuned on e85. Driveshaft shop aluminum driveshaft, 1400 hp half shafts, Detroit tru-trac. ls9 camshaft, CNC ported heads, with trunion and dual valve spring upgrade, LS9 head gaskets, ARP 2000 head studs, Manley stainless valves. Adjustable Bmr toe rods, trailing arms, rear adjustable sway bar, full cradle bushings, upper control arm bushings, BMR diff. bushings, bmr driveshaft safety loop.
camarossdusk is offline   Reply With Quote
Old 03-19-2015, 07:29 AM   #2
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
metco is what is needed for aftermarket shafts (Gforce/DSS). BMR is good for stock driveshaft.
look for a good SNELL 2010 or newer rating.
Old 03-19-2015, 01:21 PM   #3
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Bingo! You can use the Metco with stock or aftermarket, you just need their extension when using an aftermarket shaft.
Best regards,
Tyler
888-308-6007
Old 03-19-2015, 09:28 PM   #4
camarossdusk
whippled 5th gen
I was asking because a friend of mine put the bmr safety loop on his car, but needed modification to it, is that because the zl1 driveshaft is diff. than stock ss driveshaft.
Old 03-19-2015, 09:29 PM   #5
camarossdusk
whippled 5th gen
thanks for helmet advice narrowed it down a bell one found with snell 2010 dot sticker.
