Old 03-19-2015, 10:52 AM   #1
LadyT_SS
Christina
Drives: Red Jewel Tint 1SS
Does anyone run DOT 3 brake fluid anymore?
While searching for the best option for brake fluid, it seems as if everyone has swapped from the factory DOT 3 to motul 600. Should I go to motul if im NOT going to track the car? Suggestions please!
LadyT_SS is offline   Reply With Quote
Old 03-19-2015, 12:33 PM   #2
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
If your not going to road course the car, dot 3 is perfectly acceptable.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 03-19-2015, 02:57 PM   #3
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I did the upgrade to Motul because I did the CTS-V upgrade (with new stainless lines). Bee was almost 3 yrs old before I did the clutch/brake reservoir split, so I figured with all of that it was logical to go ahead and flush with new fluid. It wasn't necessary for my daily driver, but for the "add-on" price it just made sense.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 03-20-2015, 11:17 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
+1. Did ZL1 upgrade, stainless lines and motul 600.
-Don
747 RWHP 794 RWTQ
Old 03-20-2015, 11:37 PM   #5
X25
X25's Avatar
Drives: '16 C7 Z51
It's not always true, but most DOT3 fluids have a longer life than DOT4 fluids, and are more resistant to contamination. This is not much of an issue for those who go to road course track since they'd need to bleed much more often anyway, but it's a good feature if your car will never see track duty.
GM's service intervals assume DOT3. If you use DOT4, you should probably service (replace) your brake fluid more often than whatever is recommended.
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 03-24-2015, 03:43 AM   #6
LadyT_SS
Christina
Awesome!! Thanks! Since I won't be tracking her, I'll just stay with DOT 3
