Old 03-19-2015, 11:51 AM   #1
mbowen89
Drives: 2015 CRT 2SS/RS 1LE
Illegal Down Shift Prevention
Is there anything that stops you from downshifting from 4th to 1st for example? I tried to do some searching and can't really find anything.
I'm getting my first manual (a 1LE) next month, and I was just wondering what happens if you are going 80 and somehow tried to down shift into the wrong gear. Are you locked out if it's too low?
Does anyone ever really have this issue? I'm not expecting to accidentally do this, but it just made me curious...
mbowen89 is offline   Reply With Quote
Old 03-19-2015, 11:54 AM   #2
Mean Green Z28
Drives: 2010 2SS
Nope, you can pretty much shift to any gear except reverse due to the lockout (just a tough spring that could be pushed against still).
2010 2SS - CAI Intake, ADM Scoop, RotoFab Washer relo. LT Headers and off-road pipes, X-pipe, Muffler Deletes, ZL1 Spoiler, Technostalgia Tail-lights
'98 T/A (Sold) - Forged 6.0ltr, MS3, P&P'd Heads/Valves, 90MM FAST/TB, Headers, 3" Y-pipe, 4" Mufflex Catback. Koni Adjustables w/GC coilovers (550/175), Strano Sway Bars
'94 Z28 (Sold) ... LS1 swap (basically same setup as the T/A), TH350/3500 stall ... swapped it all into the T/A
-- >> Some of my Projects My Fquick Page
Mean Green Z28 is offline   Reply With Quote
Old 03-19-2015, 12:09 PM   #3
mbowen89
Gotcha.
For the most part, even at 80mph highway driving, unless you throw it in first, you should be ok then, correct?
Is it pretty hard to accidentally miss 3rd and throw it in first? I guess I don't really hear many people doing that on here.
Old 03-19-2015, 12:16 PM   #4
Mean Green Z28
Drives: 2010 2SS
Nah, unless you're being really crazy with your shifts, you'll be fine. Something that's always worked for me and helped me not mis-shift has been the way I hold the shifter during "spirited" driving. Thumb up/down depending on which gear you're in and going up/down. Usually thumb-down shifting higher, thumb-up shifting lower. The natural tendency of your arm movement also forces a "safe" direction of shifter travel
Also if I remember correctly, it's pretty hard to get into the first two gears at speed ... going driving now, will update haha
also, remember there's also the 2-3 gear lockout when taking off slowly, forcing you to go from 1st to 4th ... that's only for low speed and shifting up though
Old 03-19-2015, 12:27 PM   #5
45thAnniversary2SS
45thAnniversary2SS's Avatar
Drives: 2012 45th Anniversary 2SS LS3
This car was my first manual as well OP. Don't sweat it, you will be fine.
45thAnniversary2SS is offline   Reply With Quote
Old 03-19-2015, 12:28 PM   #6
Mean Green Z28
Drives: 2010 2SS
Tried shifting to 1st at local speeds, can't unless I break the syncros lol
Old 03-19-2015, 12:31 PM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
To go from 4th to 3rd you just push the stick forward. To hit 1st you would have to push forward, then to the left, then forward. It would be a really hard mistake to make.
Old 03-19-2015, 12:36 PM   #8
malave7567
malave7567's Avatar
Drives: 2015 Camaro 1SS
A more common mistake I have seen is downshifting from 6th to 3rd on the highway and accidentally going back into 1st. However, it requires a lot of force to do, so just think before slamming into a downshifting. The two guys that I've known to do this abuse their cars regularly and probably just slam into every gear "because racecar," they say. It slides in a lot easier if the synchros aren't having to deal with that huge a jump.
Full disclosure, both incidents were not on 5th gen Camaros.
malave7567 is offline   Reply With Quote
Old 03-19-2015, 01:28 PM   #9
mbowen89
OK, so basically, it will have a definite noticeable harder time going into a gear that you shouldn't be going into, inherently because of the synchronizer. So if one did accidentally try to do a 6th-1st, there would be a lot more resistance, and you'd have to intentionally bang it in there hard to get it to go.
Which ties in to how you should be shifting in the first place. You don't need to be hard-banging the shifter around, so "gentle shifting" should prevent anything like this from ever happening in the first place.
Makes me feel better! I'll just remember to be easy on the shifter, and if it doesn't feel right, don't force it.
Old 03-19-2015, 01:39 PM   #10
I4toV8
Dazed &
I4toV8's Avatar
Drives: matte blue 2014 z28(186) 2015 R1
im just going to leave this here.... (discuss)
http://www.streetfire.net/video/clut...rom_197990.htm
op take it with ease and you will be fine.
I4toV8 is offline   Reply With Quote
Old 03-19-2015, 02:45 PM   #11
Jims73z
Jims73z's Avatar
Drives: 1973 z28 Rs , 2012 SS/Rs Blk/Blk M6
I think on the tremecs it's much easier to shift from third to second. mechanical
over rev and bent pushrods were a popular mod on fourth gens.
Jims73z is offline   Reply With Quote
Old 03-19-2015, 07:30 PM   #12
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
That was cool .
1Coopgt is offline   Reply With Quote
Old 03-21-2015, 03:42 PM   #13
i2disturbedSS
i2disturbedSS's Avatar
Drives: 2010 SS L99 IOM
That's what I've heard also
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins
i2disturbedSS is offline   Reply With Quote
Old 03-21-2015, 10:57 PM   #14
Edzo
Edzo's Avatar
Drives: 2013 Camaro SS and 63 Impala
The thing that might stop you is the windshield. If this is a serious question, you shouldn't be downshifting from 4th at 80!
Edzo is offline   Reply With Quote
