![]() Drives: 2015 z28 sold Join Date: Dec 2014
2015 Z28 two days at track..hurt motor?
As title says
Two days at the track..first time I pushed the car a little in a TT class revving to redline and the check lamp comes on..starts flashing..car was dropping one or more cylinders on track. Code po300 and po306 come up for misfire when scanned in the pits. Reset it....went out for a 5/10ths lap and the felt like crap...but no lamp or code. Reset the ECM...unhooked the battery ..and parked the car for the day. Driving home mil came on....it ain't a bad injector or coil..engine internal..ran some testing to confirm this...don't care to get into it further as there are a lot of arm chair mechanics on the web. Moral of the story don't flash your ecm and void your motor warranty with the ls7 Great car I think..just weak motor. Last edited by MARKSTI; 03-21-2015 at 07:41 AM. |
![]() ![]() ![]() Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
OUCH!
#3 | |
![]() ![]() ![]() Drives: 2016 Nightfall Gray Metallic SS Join Date: Dec 2013
2016 Nightfall Gray Camaro SS |
![]() ![]() Drives: 2021 300 Join Date: Jan 2015
Very sorry about the motor. Some of us older guys try to warn the newbe's just how important that warranty is. again very sorry maybe after a cool head you can look at it and maybe something you can do..
#5 | |
Before I tracked the car I spoke to the service manager of the dealership...he advised me not to flash the car since this would void the warranty if we had motor problems as some of the ls7s do. |
#6 |
Okay. I understand now.
What's the cause of the failure? Is your engine completely stock?
#7 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
OP. Sorry to hear about your motor. Hopefully you can get quick resolution on warranty work. I would be sure to have the engine rebuilt versus replaced if it were mine.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
LS7 failures happen most often with faulty valve guides and dropped valves...please post the exact failure once it is diagnosed
#9 |
![]() Drives: 2015 Z28 Join Date: Feb 2015
Sucks....
See what the dealer can do for you
2015 Z28 Track Car
#10 | |
Yea the motors stock. The cars was on redline 1050w oil I can't really go into many more details...warranty is pending. I ran the track the same way in my 2013 boss for almost 2 years and a GTR and had no problems. |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
"Code po300 and po306 come up for misfire", those two codes look soooooooo familiar.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2013
Please report back here so we will all know what happened. I hate to here you had this trouble.
#13 |
![]() Drives: 2012 Ram 1980 Malibu Join Date: Apr 2013
Sounds like thee ol Z06 valve drop
Hope its not and hopefully GM will take care of you |
#14 |
![]() Drives: 2014 white Z/28 Join Date: May 2014
Sorry to hear You had problems with your motor. Kinda takes a little pride In ownership away from you when this happens so soon in taking ownership of a vehicle. With all the hype this car has from G.M. calling it a "street Legal" racecar I would hope you would be fine because you are just doing what this car was designed to do. Right? Now I can only hope you can get past this unscathed and regain what you lost and get back to having fun with your car.
