Old 03-20-2015, 08:59 PM   #1
grendel
Faster Mabricator
Drives: 73 Camaro with 5th gen stuff
5th Gen Camaro Brembos... with a z06 hub.
Greetings,
If you check my build thread on Lat-g, you'd see that we put a 5th Gen Camaro IRS into the back of my 73 Camaro.
So far, we used the Camaro knuckles with a Z06 unit bearing. The Camaro Brembo rotor fits loosely over the wheel studs, but not the unit bearing register.
Before I open up the Camaro rotors on a lathe, is there a stock rotor that will fit Z06 pattern, the Camaro SS in rotor hat e-brake shoes and Brembo SS caliper?
I am thinking Z06 rotor, but it's an expensive experiment, since I can't return the rotor if I fit it up.
grendel is offline   Reply With Quote
Old 03-20-2015, 10:33 PM   #2
grendel
Faster Mabricator
For the record, I flopped back to the Camaro hubs and they fit the Corvette Z06 rims I have.
Old 03-21-2015, 12:54 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Don't have any answers for you but I really like the 2nd gen cars could you post a pic of your car???
Old 03-21-2015, 01:00 PM   #4
grendel
Faster Mabricator
I have a very large build thread on another board.
It's certainly still a work in progress.
For the record, I have a solution . Don't use the ZO6 rear hubs.
Old 03-21-2015, 11:32 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
NIIIIICE!!!!!!
