FE4 Upgrade help!
So I need some help!
Was about to tackle my FE3 to FE4 upgrade this morning and want to confirm I am in fact missing pieces needed.. 2010 SS here. So I have the OEM LCAs (2012+ part number 20942237), BMR front and rear sways (SB039), and the rear end links (part #22761221). But I think that I am short of everything I need. Do I need new FRONT end links also for the conversion? If so, can someone help me with a part number? Thanks for any help in advance - still holding on hope I can do this today with confirmation here and some luck GM has them in stock locally. Thanks!
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Hold it! Just saw this was designed for newer 2013 on cars! You will need the newer front endlinks... !
Drives: His Wife Crazy Join Date: Jan 2008
yes, but you said that you already had the newer front end links,
this is why i mentioned that you would need the 12mm drill for the front strut hole that the end link goes in to since your strut has a 10mm hole. |
Yeah I knew that I just never bought the front end links. Think I confused myself. I only bought the rear end links so guess new one needed
#5 | |
Wait what?? I haven't boughten the front end links yet. I guess missed them somehow! I just need to find the part #s
#6 |
Fro the time being you can use the 10mm links that you have, just make sure they are tight, (and keep in mind they might loosen up a bit and make noise)
Also you can look locally for a 10mm ID and 12mm OD metal bushing/spacer that is shorter than the swaybar is wide and that will give you more time to get the newer style links. |
#7 |
are you looking for stock part numbers or aftermarket?
#8 |
Stock was what I was looking forb
#9 |
check the post that i just bumped about Suspension Codes
#10 |
'It's an experiment'
Craig: we're you able to locate them?
-Don
747 RWHP 794 RWTQ
#11 |
I think so not sure. Dealers no real help. I have these as part numbers for the newer front end links (12mm) 22842515 and 22842516
#12 |
Those look like the right numbers for a 12 2ss...
http://www.gmpartsdirect.com/catalog/frameset.cfm That is the link I have... -Don
747 RWHP 794 RWTQ
#13 |
Thanks Don! Will order now!
#14 |
I do have a '13 service manual I can ck when I get home...
-Don
747 RWHP 794 RWTQ
