Old 03-22-2015, 08:41 AM   #1
ADM PERFORMANCE
Drives: Anything I want
ADM PERFORMANCE builds another 700+rwhp
So we are cranking ZL1's out every week now.....Check this one out we are building
Combination -
ADM Race Intake
Rotofab Biggulp
ADM Ported Snout
2.5" pulley
9.15 pulley
Tr7ix plugs
ADM Stage 2 ported Heads
Arp Head studs
ID 1000 Injectors
ADM Oil Cooler
ADM Air Fuel Gauge
Detroit Speed Swaybars and Springs
Road Race alignment
Autocal with Dual tunes - 91 oct and Torco91
Btr stage 3 cam
ADM Heat exchanger by Ron Davis
ADM PERFORMANCE is offline   Reply With Quote
Old 03-22-2015, 08:49 AM   #2
ADM PERFORMANCE
Engine prep
Here is the work in progress
Old 03-22-2015, 09:02 AM   #3
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
Incredible! Great job Andy. Always top notch work from ADM and Starkweather Performance!
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 03-22-2015, 10:09 AM   #4
Dutchman427
Drives: 2012 ZL1 #1329 M6
Very Nice!
Dutchman427 is offline   Reply With Quote
Old 03-22-2015, 12:24 PM   #5
ADM PERFORMANCE
Wow it's dirty- from Michigan i believe
Lots of cleaning still
Old 03-22-2015, 12:27 PM   #6
ADM PERFORMANCE
Wow what a differenc
We do this to every build
Old 03-22-2015, 12:54 PM   #7
DrkPhx
DrkPhx's Avatar
^^^ That's a big difference. How many miles are on that car? I'm surprised you don't go with a bigger heat exchanger for such a monster set up. Is that a regular Ron Davis exchanger and do you stock them?
Old 03-23-2015, 03:38 AM   #8
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
Those pics look great.
What do you have do to remove the cradle bushings? Do you need to press out the oem bushings?
I would like to do this upgrade. Thanks, Sam.
NW Sam is offline   Reply With Quote
Old 03-23-2015, 06:52 AM   #9
ADM PERFORMANCE
Ok
We use them all the time,currently awaiting on our restock order to arrive.
Not sure what you mean by bigger as we have 3 times the capacity,equal airflow through the core of a factory,no issues with a/c or overheating due to its design.
We have used them for years.
The car had 8000 I believe.
Old 03-23-2015, 06:53 AM   #10
ADM PERFORMANCE
We cut them out.New ones can be installed with a a little force.
Old 04-05-2015, 10:07 AM   #11
ADM PERFORMANCE
ALL TOGETHER
Here are some more pics of this build.We added a better oil cooler(FLUIDYNE) to this car as it will see a lot of track miles at EAGLES CANYON.
We also tuned it for Race gas and 91 octane .
Old 04-05-2015, 10:16 AM   #12
ADM PERFORMANCE
Some final PICS
So we finished this car just before the TEXAS MILE . Notice the upper control arm CARBON FIBER COMPOSITE BUSHINGS
Old 04-05-2015, 10:32 AM   #13
ADM PERFORMANCE
Final dyno numbers ZL1 750+ Package
Here is the break down of the car:
Pre dyno stock on 91 octane - 473 rwhp and 501 rwtq
ADM ZL- 750 Package on 91 octane - 11PSI - 673rwhp and 678 rwtq
ADM ZL-750+ Package on 91 octane - 14 psi boost - 710rwhp and 710 rwtq
ADM ZL-750+ Package on Torco and 91 octane - 14psi -766rwhp and 768 rwtq
Old 04-05-2015, 10:49 AM   #14
Smittty
Smittty's Avatar
Drives: 2013 ZL1 Camaro 2000 SLP Camaro
Looking good Andy.
2013 ZL1 748rwhp & 733 rwtq ( 93 tune )
Smittty is offline   Reply With Quote
