Old 03-22-2015, 10:38 PM   #1
SSNYSTR
SSNYSTR's Avatar
Drives: Black 2011 Camaro 2SS
Lower Springs
Might be a dumb question, but do lowering springs do anything besides lower your car as in suspension wise? Or is it that same as your factory springs, but shorter springs?
SSNYSTR is offline   Reply With Quote
Old 03-23-2015, 12:31 AM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I have BMR 1" springs and my car feels better when going through the cones during autocross. It doesn't seem to have as much body roll side to side as my brothers stock sprung car does. It also seems to help out the feel of the car, such as it's easier to feel what the tires are doing as far as grip is concerned.
It does also stiffen the ride a bit, but it's not super stiff.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 03-23-2015, 05:10 AM   #3
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
Some have better spring rates and lower the car. get some sways and you have a whole new car!
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 03-23-2015, 10:22 AM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
A good set of lowering springs will have some performance benefits over stock. The obvious one is that the car is lower. While most people do this for cosmetic reasons, it also has performance benefits because it lowers the center of gravity of the car. The biggest benefit is in improved spring rates. Aftermarket springs will use a higher spring rate than stock springs which will decrease body roll in the corners.
Check out the thread below. It has a lot more info that you might find helpful.
Understanding Lowering Springs
Old 03-23-2015, 10:44 AM   #5
SSNYSTR
SSNYSTR's Avatar
I'm not doing any kind of track racing. Most I'll be doing is drag racing a few times a year.
Old 03-23-2015, 10:51 AM   #6
Apex Motorsports
You don't have to go to the track to enjoy the benefits of suspension upgrades. They make driving in general a lot more enjoyable.
Old 03-23-2015, 12:22 PM   #7
richard200593
richard200593's Avatar
Drives: 2012 45th Anniversary RS
If you go with springs your ride will be a little more harsh but it will feel more "planted" speed bumps hurt more but you feel more comfortable taking corners at higher speeds
*Performance:
mrt v2.0 exhaust/CAI Intake
*Cosmetic:
Zl1 factory Reproduction wheels
Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights
*Audio:
Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box
richard200593 is offline   Reply With Quote
Old 03-23-2015, 01:58 PM   #8
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
A LOT less body roll through the corners
Tmick5jr is offline   Reply With Quote
Old 03-24-2015, 01:33 PM   #9
aFe POWER
aFe POWER's Avatar
Drives: Camaro
Better cornering confidence, better aerodynamics, and much nicer look to your vehicle.
aFe POWER is offline   Reply With Quote
Old 03-24-2015, 02:11 PM   #10
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Springs with stiffer rates will also help prevent the squat and dive that happens during acceleration and braking.
On an IRS car, when the rear squats, you'll gain negative camber and toe changes. This affects traction in a negative way. A good, stiffer spring will help, but you don't want to go too low, otherwise you'll need adjustable LCA's and toe links or eccentric bolts to correct the camber gained.
Best regards,
Tyler
888-308-6007
Old 03-24-2015, 02:15 PM   #11
Rob@WretchedMS
Drives: His Wife Crazy
+1 to everything everyone else said, with the added factor that you can have bragging rights over the others that are not lowered. Everyone knows that bragging rights is why we do the things that we do, lol
Rob@WretchedMS is offline   Reply With Quote
Old 03-25-2015, 01:18 PM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
A Lowered Performance Spring will have a different Rate so it works correctly - as now a shorter spring has to hold up the weight of the car & perform. Our Front V-8 Lowering Springs have a 220 rate
