Old 03-23-2015, 10:54 AM   #1
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
Clutch vibration to clutch is broke
Posted this in the transmission section but I think I'll get more responses here.
http://www.camaro5.com/forums/showthread.php?t=401033
I picked up a vibration in the clutch that I can feel only through the clutch pedal. It's vibration is consistent with the RPMs and I can feel it by resting my foot on the pedal and all the way through max pedal travel. What are your guys' thoughts on what it may be. I'm suspecting throw out bearing or pilot bushing.
Other than picking up this vibration, clutch has been working great.
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 03-23-2015, 11:24 AM   #2
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I get a vibration noise when shifting at high RPM,s but everything works great. I have had this since new. I have not thought it was a big deal, but would love to hear more from others if they have the same thing.
gajagfan is offline   Reply With Quote
Old 03-23-2015, 11:55 AM   #3
White_SS/RS
Drives: 14 1LE
no noise associated with mine. It's not even that big of an issue but since I just started having the vibration, I know something has changed or worn. I'd like to see if I can fix the issue before it became a bigger problem.
LMS Engineering
Old 03-23-2015, 11:58 AM   #4
Steve@SNL/Monster Clutch
Drives: 2014 SS
Sounds like a release bearing issue.
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 03-23-2015, 12:45 PM   #5
White_SS/RS
Drives: 14 1LE
What usually causes the problem? And what kind of damage would I be looking at if it completely fails?
LMS Engineering
Old 03-23-2015, 02:04 PM   #6
Drives: 2014 SS
Excessive heat and abuse.
Old 03-23-2015, 02:25 PM   #7
gajagfan
gajagfan's Avatar
Steve@SNL, can you define abuse?
Old 03-23-2015, 02:32 PM   #8
jcamo
jcamo's Avatar
Drives: 2ss/rs/2013 camaro 1LE
I too would like to know ... I have 6500 miles on my car with no abuse what so ever on it and I seem to have this same vib in my clutch pedal. It's very faint but never the less It's there. If it's heat what would cause that. I would think maybe slipping the clutch could cause heat but I never do that as it's not needed in my style of mild driving..
jcamo is offline   Reply With Quote
Old 03-23-2015, 02:33 PM   #9
Drives: 2014 SS
Anything outside of standard daily driving.
Old 03-23-2015, 02:38 PM   #10
backeddy
Banned
Drives: 2011 Boxster Spyder (best car ever)
Let's not ask GM CS to chime in on "abuse"...LOL .Sorry to hear about your issue, I am sure Steve @ monster can set you up!
backeddy is offline   Reply With Quote
Old 03-23-2015, 02:39 PM   #11
White_SS/RS
Drives: 14 1LE
Well I do track it. Seems my clutch time has come like so many others. Lol. Do I just need the slave assembly to fix the issue? What are my options?
LMS Engineering
Old 03-23-2015, 02:43 PM   #12
backeddy
Banned
How many miles are on the car? I have 16k and 7 or 8 track days, with no issues yet (fingers crossed)
Old 03-23-2015, 02:50 PM   #13
White_SS/RS
Drives: 14 1LE
I know, Right!?
I'm well read up on everyone's clutch issues and am not seeking GM on this issue regardless of why it's failing. Biggest reason is I don't want the same parts again, obviously stock parts don't cut it.
LMS Engineering
Old 03-23-2015, 03:05 PM   #14
White_SS/RS
Drives: 14 1LE
8500 miles. About 1k of them are track miles.
LMS Engineering
