Old 03-25-2015, 12:18 AM   #1
DaFisch
Master Amateur Mechanic
DaFisch's Avatar
Drives: Victory Red 2011 2SS/RS
Need opinions on Duraflex Peices
I know most people here stay away from duraflex. My rears are running 315's. The tyres are rubbing on the rear fender and short of changing to coilovers I don't know wht else to do (full bmr suspensiom including 1/1.4 inch drop)
I stumbles upon these and they are the closest thing i could find to fender flares like the z28. I like them, what do you guys think about them/duraflex?
http://pages.ebay.com/link/?nav=item...d=191478784819
DaFisch is offline   Reply With Quote
Old 03-25-2015, 12:36 AM   #2
jgray1978
Drives: '12 2SS/RS 45th vert, '14 2SS/RS
$562 just for 2 fender flares??? Are they high?
Honestly the flares would look cool if they remained complete all of the way around instead of tapering down behind the wheel...But $562 for two pieces of ill molded plastic? No way!
jgray1978 is offline   Reply With Quote
Old 03-25-2015, 01:13 AM   #3
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
How would these awful fender flares or changing over to coilovers help with you your tires rubbing the fenders? Seems like it's a wheel offset issue. With the correct offset wheels and tire size, 315s can fit no problem.
Avalnch is offline   Reply With Quote
Old 03-25-2015, 02:34 AM   #4
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
I agree, unless you plan to cut away the factory wheel well and roll them out to match the flare you will still rub...
13blackLS is offline   Reply With Quote
Old 03-25-2015, 12:34 PM   #5
DaFisch
DaFisch's Avatar
I'd roll the quarter panel fenders. I have correct recommended offset and still rub
Old 03-25-2015, 07:13 PM   #6
Avalnch
Avalnch's Avatar
What are your rear offsets? To run a 315 properly, you need 20x11 at +43 or +45 mm offset.
Old 03-26-2015, 12:00 AM   #7
13blackLS
13blackLS's Avatar
Im on a 315 and lower than 1.4 in the rear and have no rubbing issues, where are you rubbing? Ill rub the the top of the fender above the wheel on hard dips if im going too fast, but dont even come close the the fender arch on a 20x10.5 wheel
Old 03-26-2015, 03:14 PM   #8
BigBlock427
ConceptZer0
Drives: 68 427 Camaro, 11 2SS/RS, 13 ZL1
What about these Z28 replicas?
http://www.ebay.com/itm/10-15-Durafl...48d996&vxp=mtr
BigBlock427 is offline   Reply With Quote
