Old 03-25-2015, 12:54 AM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Koni Orange vs. OEM V6 Shocks
Hi All,
First, there seems to be a lot of variance when it comes to the mileage for replacing shocks. Most resources online are also trying to sell shocks, so its hard to know how realistic they are being. When are you guys replacing your shocks?
Secondly, for those who have some experience. Would the Koni Orange shocks be a big improvement over buying another set of OEM shocks?
I have the v6 camaro btw
Thanks Guys!
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 03-25-2015, 01:01 AM   #2
JohnZ
JohnZ's Avatar
Also, I don't auto-cross or go to the track. I occasionally enjoy spirited drives through the canyon, but that is about it.
Old 03-25-2015, 12:03 PM   #3
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
OEM struts are cheaper and the Koni will make the ride a bit stiffer, so if you don't track/autocross you might be better off sticking with new OEM parts.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 03-25-2015, 02:48 PM   #4
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Remember Shocks & Struts don't last forever - a lot of that depends on the quality of the Shock & how you drive. A General Rule would be 50,000 - 60,000 Miles, but I have seen Cheap Shocks go bad in a month
Old 03-25-2015, 06:19 PM   #5
JohnZ
JohnZ's Avatar
@BMR - How would you compare the OEM shocks on a v6 to the Koni Orange shocks?
Old 03-25-2015, 09:47 PM   #6
Destructo09
I'm not sure I can recommend Koni oranges at this point, my brother and myself both have issues with clearance now. There is some slight difference between Koni oranges and OEM struts. The issue is with clearance to the spring perch, not the tube.
At this point, I would just go with OEM, because there really isn't anything else out there right now until Koni figures out what they did wrong.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
Old 03-25-2015, 09:55 PM   #7
Irace16
Irace16's Avatar
Drives: 2010 1SS RS M6
What kind of clearance issues are you having? I m seriously considering koni oranges
Vararam intake, gmpp exhaust, borla stainless long tubes, cat less, jannetty tune, bmr lowering springs, heritage grill , smoked lenses
Irace16 is offline   Reply With Quote
Old 03-25-2015, 10:01 PM   #8
Irace16
Irace16's Avatar
Never mind , saw your other thread
Old 03-25-2015, 10:04 PM   #9
Destructo09
Yep, check it out, probably ok if you're running 245s up front, but otherwise you'll need to be careful. Even my 245s started rubbing the rubber nipple from the spring isolator though. If that was it I wouldn't be very concerned.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
Old 03-26-2015, 02:36 AM   #10
JohnZ
JohnZ's Avatar
Thank you for the input, I saw your thread. OEMs are looking good right now.
Old 03-31-2015, 12:26 AM   #11
DP Valentino
DP Valentino's Avatar
Drives: 2010 CGM Chevrolet Camaro LS
I would recommend going to FE4 SS Struts all around or getting 1LE Struts all around with lowering springs. I have FE4 SS Struts with Hotchkis Lowering Springs all around. The ride is a little more firmer on the streets, but will handle the ride through the mountain canyons.
2010 Chevrolet Camaro CGM LS - Performance Mods: "Everything I can get bolt-on wise to make it run good!"
Exterior Mods: "Everything I can get to make it look good!"
Interior Mods: "Everything I can get to make it look good!"
DP Valentino is offline   Reply With Quote
