Old 03-25-2015, 07:34 AM   #1
domano 68
domano 68's Avatar
Drives: 2014 1LE
Right rear tTire loosing pressure
Loosing about 3-4 pounds per week. No nail, screw or anything found that has punctured the tire. TPMS reading is same as a manual gauge so the TPMS is working good. Just wondering if this has popped up before. Will be taking to the dealership soon. Thanks in advance.
domano 68 is offline   Reply With Quote
Old 03-25-2015, 08:04 AM   #2
ForcFed93
Drives: 2001 2500HD
Take it off and submerge it in water. You'll find the leak. It's either in the tire itself, the bead seal, or the valve stem. My guess is you have a tiny puncture in the tire itself that you just can't see unaided.
2001 ECSB 2500HD
ForcFed93 is offline   Reply With Quote
Old 03-25-2015, 08:18 AM   #3
domano 68
domano 68's Avatar
Drives: 2014 1LE
Yeah, good idea. Will need to find a bucket or tub bid enough for submerging.
BTW, what is the stud torque value for these wheels? Will need to know that when putting the wheel back on. Thanks.
Old 03-25-2015, 08:25 AM   #4
Billy10mm
Billy10mm's Avatar
Drives: 2014 Camaro 2SS 1LE NPP
110 ft-lbs
Billy10mm is offline   Reply With Quote
Old 03-25-2015, 08:25 AM   #5
ForcFed93
Drives: 2001 2500HD
110 ft. lbs.
2001 ECSB 2500HD
Old 03-25-2015, 08:34 AM   #6
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
You can also use soapy water and a spray bottle.
Pump the tire up to full pressure, spray a mild soapy solution on the tire, look for the bubbles.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 03-25-2015, 08:40 AM   #7
Mark T
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav
Yes I prefer the soapy water to. It makes bubbles really easy to see. And you dont have to pull the wheel. Spray in place and just watch for bubbles forming.
Mark T is offline   Reply With Quote
