Old 03-25-2015, 12:42 PM   #1
Ladykiller
Drives: 2013 Camaro ZL1
If you ordered a 2013 ZL1 Coupe w/ ECF insert w/stripe & w/o sunroof, I need a favor
So, I have a 2013 Silver ZL1 Coupe with the exposed carbon fiber insert (ECF), automatic, no sunroof. I want to get the factory stripe put on. Problem is, I am not sure what part number(s) to get. Between my dealership and gmpartsdirect.com, I see multiple color variants which are similar, but not the same. I assume the differences are for the regular hood insert and the ECF insert.
So the favor I need to ask is .... if you ordered your ZL1 from the factory as a coupe with the ECF option w/o sunroof for 2013 (or newer possibly), can you please PM me your VIN number? My parts guy at the dealership said he could compare my VIN and your VIN and determine the exact P/N for the correct color stripe. I would really appreciate it as I want this to look as factory as possible, even though I know the antenna won't match.
Thanks.
Ladykiller is offline   Reply With Quote
Old 03-25-2015, 02:53 PM   #2
CompulsiveZL1
CompulsiveZL1's Avatar
Drives: 2013 IOM ZL1 M6
Ladykiller, here is the last eight of my vin: D9805802. Should work for you. I have a 2013 ZL1 no sunroof with stock roof stripe and exposed carbon hood insert.
Good Luck!
CompulsiveZL1 is offline   Reply With Quote
Old 03-25-2015, 03:14 PM   #3
papsz
Drives: Crystal Red 2013 ZL1
DSW is the rpo code for the gray stripe w/exposed carbon fiber hood insert.
papsz is offline   Reply With Quote
Old 03-25-2015, 03:39 PM   #4
Ladykiller
Thanks guys!
Old 03-25-2015, 03:52 PM   #5
yoshie
Drives: ZL1, ,GMC Z71 ,TJ
Order my car with stripe only came on trunk because of sunroof this the part number for roof #22956994 (exposed C/F )
yoshie is offline   Reply With Quote
