Old 03-25-2015, 02:52 PM   #1
Explit Player
IG @Brian_ _Self
Explit Player's Avatar
Drives: 2010 Camaro 2SS M6+17'Tesla Model S
Sunroof sliding cover cleaning
I know this is not the place for cleaning and washing discussions, but it is how to's. And I am wondering how to get to the top of the sunroof sunshade to clean it, because mine has a green film over the top of the plastic if you look into the sunroof while it is propped open. So how would I go about getting access to that?
Explit Player is offline   Reply With Quote
Old 03-25-2015, 11:47 PM   #2
poorboy10
Drives: 2010 2ss
I would like to know too. I just noticed mine with that green film too.
2010 l99 summit white w/inferno orange stripes and interior. Texas Speed longtubes, halltech cold air intake,v-max ported throttle body, MSD wires, NGK plugs, Spintech catback with x-pipe, GPI SS1 VVT camshaft.
poorboy10 is offline   Reply With Quote
Old 03-31-2015, 09:39 PM   #3
Explit Player
IG @Brian_ _Self
Bump
Old 08-18-2015, 09:57 AM   #4
Explit Player
IG @Brian_ _Self
Any bump on this guys? I still have that nasty residue
Sent from my VS986 using Tapatalk
Old 08-18-2015, 11:03 AM   #5
MR.Sarge
MR.Sarge's Avatar
Drives: 2015 2SS/RS 1LE
pic of what your talking about?
MR.Sarge is offline   Reply With Quote
Old 08-18-2015, 04:01 PM   #6
Explit Player
IG @Brian_ _Self
Its the sunshade slider under the glass. Ontop of the slider, there is like a green mildew film that isnt wanting to come off
Sorry the pic is rotated
Old 08-18-2015, 04:10 PM   #7
clashley1976
clashley1976's Avatar
Drives: 2011 Camaro 2LT RS M6
My guess is that you have to drop the headliner to remove the cover.
-Cameron Lashley
Albany, GA
2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes
CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate
Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992
clashley1976 is offline   Reply With Quote
Old 08-18-2015, 04:14 PM   #8
Explit Player
IG @Brian_ _Self
Oh lawd jesus
Old 08-18-2015, 04:36 PM   #9
clashley1976
I've got a sunroof, and I will take a look at my car later after I leave work. I read something online that may be helpful, but want to check it out with my vehicle to see if makes sense before I post it here. Will post again in a few hrs.
-Cameron Lashley
Albany, GA
Old 08-18-2015, 04:37 PM   #10
Explit Player
IG @Brian_ _Self
Thanks man!
Old 08-18-2015, 08:13 PM   #11
clashley1976
Sunroof shade removal
I did some digging around online and found this link which is apparently an online version of some sort of workshop manual for a 2010 V8 6.2L. This link seems to specifically reference the shade for the sunroof:
http://workshop-manuals.com/chevrole...ce_and_repair/
I tried it on my car, and while I didn't have the balls to completely remove the shade, I was able to get the cover out from under the glass so it could be exposed:
Start by opening both the shade and the glass about halfway.
I did this from inside the car, but I guess you could do it from outside... grab the front edge of the sunshade in the middle, forward of the molded handle, and pull down slightly. The goal is to deflect the sunshade downward just enough so that the plastic stops (circled in red) will clear the front frame of the sunroof glass. It doesn't take much, maybe 3/8" deflection. As you pull this down, slide the sunshade forward.
Once this is completed, you can open the glass all the way and close the sunshade. This should give you access to the top of the shade for whatever cleaning/detailing you wanna do.
Just remember to "re-dock" the shade with the glass frame before closing the glass, using the same process.
Supposedly, you should be able to remove the the sunshade through the top of the sunroof opening, but I wasn't brave enough to try it on my car.
Hope this helps!
-Cameron Lashley
Albany, GA
Old 08-18-2015, 08:18 PM   #12
Explit Player
IG @Brian_ _Self
That helps one HUNNADAH percent man, i see you had the residue too, thank you soo much!
Old 08-18-2015, 08:40 PM   #13
clashley1976
Yeah, it could use a cleaning. I'll work on next time I detail the car.
-Cameron Lashley
Albany, GA
Old 08-20-2015, 11:53 AM   #14
Explit Player
IG @Brian_ _Self
Well guys, i started to attempt to clean it and i am having 0 luck... The film comes off onto paper towels and turns them green, but then it still doesnt come off of the cover? I even used goof off, and that didnt work. Im hesitant to use too harsh of materials on it, but this stuff doesnt seem to be wanting to come off? I think the plastic cover may be stained?
