![]() Drives: 2011 Camaro LS Join Date: Jan 2015
Front Bumper Issue
So, like an idiot... i pulled up in a parking lot and got a little too far over a parking block, backed up some and a little piece of rebar caught the underside of my front bumper and pulled it up some causing the clip on the driver side to pop out... was wondering if I should get a new bumper or just deal with the little uneveness.. ?
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
pics would help
I tried to upload.. not sure how though
Here where it popped out. The little bracket that held it in broke. And it's just pushed back in worried it will wiggle it's way back out
![]() Drives: 2016 Z06 Join Date: Mar 2011
It will eventually pop out. To help prevent that yiu can tighten up the bolt that holds it in place. Just don't over tighten it and snap the head off. Dont ask me how I know.
#6 |
Appreciate the feedback, you think if I took it to a body shop they could reinforce it without leading to a huge bill? If not you think I'll have to replace the whole bumper?
#7 |
Bumper
#8 |
![]() Drives: 2013 camaro ls; 2005 rx8 Join Date: Mar 2013
Trim down a washer so it sits where the hole was and epoxy it to the underside and it should hold...i dont think much force gets put there unless you pull on it
#9 |
+1
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
#10 |
Great idea man. I'll post one more pic in a little bit of what the inside of it looks like so yall can get a better idea. Been working all night and day
#11 |
Here's where it broke
#12 |
#13 |
![]() Drives: 1987 IROC-Z 5.7L 2016 1SS M6 NGM Join Date: Jan 2015
Epoxy should work. What we usually do is try to find the other piece that came off, then plastic weld it back on. It's probably stuck with the bolt that holds the bumper corner in place. Soldering gun works great for me on most plastics. Electric or gas, I like electric because you can incrementally hit the trigger til it gets to the perfect temperature for that type of plastic. Sand off the paint in the area you want to weld, get adequate fusion (deep ), both sides, and finish it off like buttering bread. Should be good as new. Be careful not to sand, or burn the paint that shows(tape). Good luck!
#14 | |
![]() ![]() Drives: 2013 Camaro ZL1, 2006 Chevy Equinox Join Date: Apr 2013
| Tags |
| bumper, camaro, cosmetic, six cylinder |
