03-29-2015, 06:47 PM | #1 |
SStrutt
Drives: 2014 Camaro 2SS/RS Convertible L99 Join Date: Jul 2014
Steering Wheel Controls Slow To Respond
Is it normal for the steering wheel controls to be slow or take a couple of clicks to register?
When I press volume up, sometimes nothing happens and have to press it a second or third time. Then it will work the rest of the way up. When I roll my wheel to skip to the next song, sometimes it works sometimes it doesn't until the third or fourth attempt. When I had MyLink I had this problem, but thought it was just the MyLink system being slow. I have since installed a Scosche daskit and see the same results on my Kenwood HU. If it is a problem with the actual controls what's the odds my warranty will fix since I have an aftermarket radio? |
03-30-2015, 09:01 AM | #2 |
SStrutt
Can anyone confirm that their steering wheel controls work 100% and that what I'm seeing isn't typical?
03-30-2015, 09:38 AM | #3 |
Drives: 2015 2ss 1le Join Date: Mar 2015
Mine only act up when I'm playing music through my iPhone (bluetooth and plugged in). I have a 2015 1LE with Mylink.
03-30-2015, 01:22 PM | #4 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Sounds like something wrong in the wiring or controls. It's not normal.
03-30-2015, 01:49 PM | #5 |
I was thinking a compatibility issue with ios8 and MYLINK. But since he's having issues with a different deck, I'm inclined to agree that it might be a wiring issue.
04-02-2015, 04:14 PM | #6 |
Drives: 2013 ZL1 416 Join Date: Feb 2013
I have the same problem with a 2011 and mylink
04-02-2015, 07:51 PM | #7 |
Drives: 2014 RS/SS Join Date: Nov 2014
I have a 2014 SS/RS also. I left the factory headunit, but added amps and a sub in the back. I do notice that sometimes it does not recognize when I hit the button to skip a track instantly. Sometimes I hit it a second time to get it to work. Not sure about the volume, don't really remember it giving me any problems. I only use the USB stick for music, not sure if that has anything to do with it. From time to time when I start the car it "forgets" the USB stick is there and somehow goes to the radio instead. I have to select the USB stick again. Strange.............
I do like how it shows me the song that is playing in the heads-up display though. That is one of the reasons I left the stock head unit in. This is the Boston Acoustics system by the way. |
04-02-2015, 07:57 PM | #8 |
Drives: 2012 Camaro 45th Anniversary RS Join Date: Nov 2012
04-02-2015, 08:46 PM | #9 |
Mine is the same, very slow. I don't even use it anymore. I just reach for the dash volume and I have the stock Boston acoustics system and the bose system in my truck is so much better in many ways.
Nice car bro!
04-02-2015, 09:24 PM | #10 |
Drives: 2014 Chevy Camaro 2SS Join Date: Sep 2014
If I' playing mp3s in from a usb drive its a little slow during indexing of the music.
G5carbon.com-SS Carbon fiber Trunk Filler Panels**Carbon fiber Heat Extractor **Z/28 Carbon Fiber Spoiler (Comming Soon)**Z/28 Carbon Fiber Rear Defuser (Comming Soon)**SS Carbon Fiber Lower Grill (Coming Soon)**Z/28 Carbon fiber Side Skirts (Coming soon)**SS Carbon fiber Cooling Plate (Coming Soon)**Camber/Caster Plates (Coming Soon)
Westcoastcamaros.com-Carbon Fiber Engine Cover (Ordered) |
04-02-2015, 10:45 PM | #11 |
04-04-2015, 04:04 PM | #12 |
Drives: 2014 2SS/RS CRT Join Date: Apr 2014
This is where I notice it the most, changing the volume. I have to hold the button up (or down) for a little over a second before it registers with the radio. I didn't have to do that with my 2012, it was pretty much immediate. I'm guessing it's a design change from the factory. Perhaps a lot of people were complaining of inadvertent channel changes or volume changes while they were driving so the engineers put a slight delay in the first press.
Lifetime Camaro guy. 1979 Z28, 1987 LT, 2012 2LS, 2014 2SS/RS
--CAI Cold Air Intake --Solo HFC |
04-04-2015, 05:09 PM | #13 |
SStrutt
Yeah mine is a 2014. I don't think it should be called a feature, more a flaw. Makes me think my Camaro isn't responsive. Just wondering what will happen when I go to the dealer, since I have an aftermarket HU installed.
04-05-2015, 10:21 PM | #14 | |
Is the music stored on the phone or are you streaming? If you change the song on the phone is it instant or there is a delay equivalent to steering wheel controls? |
