03-30-2015, 09:27 PM | #1 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
SOLVED..ZL1 noise video ..
https://youtu.be/Oin6MqcyHGw
Have a ticking noise inside my car, sounds like a baseball card in the spokes of my bike. Hear it most near center console pass seat. What do you think it is? -Bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS Last edited by bobby35ny; 04-01-2015 at 03:25 PM. |
03-30-2015, 09:42 PM | #2 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
Some joker put a zip tie on your drive shaft... Lol
03-30-2015, 09:53 PM | #3 |
Have you had her up on the lift to examine what's doing underneath? To me it sounds like 'something' maybe at stuck underneath
Sent from my iPad using Tapatalk |
03-30-2015, 10:11 PM | #4 |
just jacked it up on one side in my garage, things look good, cant see too much with the heat shield in the way, the rubber U joints front and rear look ok, what do they call those things now anyways? Not u joints, LOL
ZL1::J-E-T-S JETS JETS JETS |
03-31-2015, 08:58 AM | #5 |
Drives: 2013 ZL1 6spd blk 5 spokes Join Date: Jun 2012
It sounds a lot like something rubbing the drive shaft, drive axles. Check and make sure a tag wasn't left on a part
03-31-2015, 11:33 AM | #6 | |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
03-31-2015, 11:41 AM | #7 |
Car is now at the dealer ....I will advise
03-31-2015, 11:34 PM | #8 |
I have the exact same sound coming from mine. I was waiting for weather up here to finish snowing and what not to bring her in. Please let us know what the end result is. Thanks!
03-31-2015, 11:40 PM | #9 |
Service manager got involved as soon as the car got to the dealership and took it for a test drive and did in fact hear the noise. He was stumped. I called around 5pm today for an update. Still no findings! I was told that they will dig deeper tomorrow
04-01-2015, 03:07 AM | #10 |
Read somewhere that there is a service bulletin out for the superchargers. I guess they cause a rattling sound. Maybe mention it to them...
04-01-2015, 02:45 PM | #11 |
Drives: 2014 Camaro ZL1 Convertible Join Date: Nov 2013
I had a similar issue on mine, which came from the rear. The F8 fuse pull made it go away on mine which tells me that it had something to do with the exhaust flaps. If your rattle sound is coming from the rear it couldn't hurt to try it if you have not done so already.
Here is a link to the instructions: http://www.camaro5.com/forums/showth...ight=fuse+pull |
04-01-2015, 03:05 PM | #12 |
SOLVED!! Heat shield contact with drive shaft.
