Old 03-31-2015, 09:05 AM   #1
straka
Drives: 2015 SS
20 inch drag radial
Has anyone put a 305 MT DR on a 20x11 with an one inch drop? Is there any rubbing?
straka is offline   Reply With Quote
Old 03-31-2015, 01:17 PM   #2
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
I have this exact setup. No problem on my 1.25" pfadt drop springs.
I DD on this setup currently.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 03-31-2015, 02:51 PM   #3
straka
Drives: 2015 SS
Perfect! Thank you.
Old 04-05-2015, 09:11 AM   #4
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Looks good!! How do they do on the street?
MODS:
Old 04-05-2015, 08:30 PM   #5
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Really good. They grip great. Dropping them to around 18psi at the track and around ~20something psi when running in Mexico.
Around town they're fine daily driving, and on the freeway they're good too, but the car will move around a little bit more than the goodyear F1's do on the freeway.
Old 04-09-2015, 05:44 AM   #6
2010SSRSM6
2010SSRSM6's Avatar
20 inch drag radial
So these will be replaced with a pretty set of MS stockers when you pick your car back up.
Old 04-09-2015, 08:29 PM   #7
Vann2SS/RS
"NY5THGEN"
Vann2SS/RS's Avatar
Drives: Blk on Blk 2SS/RS M6
I have these tires, and my car is drop 1.25in also. No problem with rubbing at all.
2011, 2SS/RS, Blk on Blk, M6, CAI cold air intake, MGW shifter, Pfadt sway bars, & lowering springs, AAC led's DRL, dome, trunk, lic plate, Lloyd's custom mat's, Bowtie delete, DRL harness.
Vann2SS/RS is offline   Reply With Quote
