03-31-2015, 01:19 PM | #1 |
Drives: 2000 Z28. 2010 1SS IMB. Join Date: Aug 2009
1in drop with 315's
i have the Hurst stunner wheels. the rears are 20x11 with a +40mm offset. im looking to do a 1 in drop with SLP springs. will i have issues with this setup. im worried about rubbing on the fender. i cant seam to find any info on this. i have found some threads that say it is fine with 35mm off set but i cant find any thing related to 40.
1990 RS = First Car -SOLD
2000 Z28 = SOLD 2010 1SS/RS = Mysstique Whipple Supercharger Dyno= 618hp 555tq at the wheels IMB Silver Stripes VIN#44025 Born: 9/9/09 Delivered: 9/28/09 Last edited by halo8hkk; 03-31-2015 at 01:43 PM. |
03-31-2015, 01:30 PM | #2 |
Always Workin
Drives: 2021 Mazda MX-5 Join Date: Aug 2013
If you rub, roll them
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31 Purchased 9/3 2018 1SS 1LE, HyperBlue Metallic (Sold) 2014 1SS 1LE, Black, Twin Turbo (Sold) |
03-31-2015, 03:07 PM | #3 |
People run 315s on the ZL1 with its 20x11 +43 wheels and if I remember correctly it is an inch lower than the SS from the factory.
03-31-2015, 11:16 PM | #4 |
I'm lowered with 315s no issues
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
03-31-2015, 11:33 PM | #5 |
Drives: 2SS/RS IOM CGM Stripes Join Date: May 2009
I've been lowered 1" with 315's for 4 years. I have no with no issues either.
04-01-2015, 02:14 AM | #6 |
Drives: 2010 2ss RJT LS3 GONE.... Join Date: Aug 2011
Tire plays a factor in rubbing , different brands fit wider or narrower depending on style. for instance VS are narrow tall type, while falkens run thicker,wider.etc. Just depends on brand and size, not all 315s have same sidewall depth if you will.
GONE FAR FAR AWAY......Good bye C5
VARARAM, SWSP 1 7/8 LT'S,X-PIPE,CAT DELETE,DYNOMAX RACE BULLETTS, LSR SHORT SHIFTER ,CUSTOM BLACK EMBLEMS,MPD1 SPOILER, HP TUNE BY GEARHEAD GARAGE, INTERIOR ABL LIGHTING, CUSTOM STRIPING BY BEAVER STRIPES, EIBACHS |
04-01-2015, 08:47 AM | #7 |
thanks for the help. look like i will be lowing the car soon.
2000 Z28 = SOLD 2010 1SS/RS = Mysstique Whipple Supercharger Dyno= 618hp 555tq at the wheels IMB Silver Stripes VIN#44025 Born: 9/9/09 Delivered: 9/28/09 |
04-01-2015, 10:49 AM | #8 |
Drives: Camaro Join Date: Nov 2014
We have lowered the ZL1 with our PFADT drop springs without any rubbing issues, and those will lower the car from a 1" to a 1.25" drop at most.
04-01-2015, 01:20 PM | #9 |
It's going to be very close to the fender, but you should be fine. It's only going to stick out 3mm more than the ZL1's that run 315s all the time lowered. Worst case, you may have to camber in slightly. There isn't really anything to roll on the rear fenders of the camaro; you can pull, but nothing to roll.
Best regards, Tyler 888-308-6007 |
04-03-2015, 09:56 AM | #10 |
I did a Pfadt 1.25 drop last weekend and I'm running a ZL1 replica 20x11 with a +43 in the rear. Tires are BFGoodrich G-Force Rivals 315/35 in the rear. The tire is close to the fender but doesn't touch under hard acceleration or cornering.
Definitely check your ebrake cable once you get the cars weight back on the wheel. My ebrake cable rubbed against the inside of the wheel. You could just ziptie it to the toe rod but I wouldn't recommend it. I just don't like the idea of a ziptie holding the cable. you can loosen some of the clamps and pull a bit of a slack forward. Would also recommend covering the cable with some PVC or similar to protect in the event the cable moves again. I haven't been able to find much info on around regarding it. Maybe only affecting the earlier models? Mines a 2010. I did find a post on here that gave me the idea. Just couldn't locate it again. Also, have your camber & alignment checked. Mine needed adjustment to both after the drop.
2010 2SS Orange on Black
JBA LT, HF Cat, JBA Muffler, Pfadt Drop Springs, Razzi Body Kit 2014 Silverado 6" Fabtech, 35 Baja ATZ, FloPro Catback |
04-03-2015, 10:06 AM | #11 |
Flying da helicopter
You should be good with no rubbing.
04-09-2015, 01:34 AM | #12 |
Drives: 2012 2SS/RS Rally Yellow w/ blk Join Date: May 2012
Anyone have pics of their cars lowered on 315's and +40 offset?
Don't mean to try and thread jack but I'm looking to lower an inch here in the near future as well. |
04-09-2015, 02:13 AM | #13 |
TEAM NIGHTFURY
Drives: 2010 2SS/RS Join Date: Jun 2014
You will be fine I'm lowered 1.5 on 20x10 front 20x11 rear with 315 pilot super sports which run big and it clears fine. Just zip tie the brake line back.
04-09-2015, 02:17 AM | #14 |
TEAM NIGHTFURY
Only pic I have for now
