Old 03-31-2015, 08:19 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
whipple whine
looking for some input on whine causes..car sounds and runs great, makes no noise or whining when cold, after car gets up to operating temps the whine starts and is very obvious..especially if you have another whipple ls3 next to it..car still runs perfect with the whine, whine does not seem to affect power{ not really pushing it as it may be a bearing and do not want to cause any disasters}..if car sits 20 minutes, it whines pretty much on start up..has to be totally cold for it to sound normal for 5-10 minutes of running..spoke with mike@ whipple and he listened to video, said it could be a bearing or air leak..he could not be sure..hoping someone has heard a similar whine and has a good idea of what it is , befiore I tear it down and send to whipple..just want to mention , mike at whipple has gotten back to me under 24hrs and will do what he can to help get issue reolved..just what you want in a vendor with such a expensive mod..video whine is real obvious near end, when I give a few short rev,s..it is not any pulley and oil is halfway in the glass eye..thanks in advance..here is youtube link , if it does not attach here..
mikepage0007 is offline   Reply With Quote
Old 03-31-2015, 09:15 PM   #2
Mr. Nasty
Emerald Coast Camaros
Mr. Nasty's Avatar
Drives: 2010 RS/SS Rally Yellow & 68 SS
Don't know mike, mine has never made that sound. I would say it a bearing from the sound of it.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135
AS OF 1/31/15 @ 633 RWHP=10.16@135
AS OF 1/29/16 @ 633 RWHP=10.10@136
TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF
Mr. Nasty is offline   Reply With Quote
Old 03-31-2015, 10:01 PM   #3
yotaman96
yotaman96's Avatar
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6
Sounds like it needs to go in for inspection.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2002 Trans Am
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 03-31-2015, 10:37 PM   #4
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
Yea I would get that off and back to Whipple before it destroys itself and takes other things with it.
elarson5757 is offline   Reply With Quote
Old 03-31-2015, 11:28 PM   #5
Ret Fuzz
Banned
Drives: 2010 Camaro
definitely sounds like a bad bearing.... They growl at lower speeds.
Ret Fuzz is offline   Reply With Quote
Old 04-01-2015, 08:27 AM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Keep us updated on the issue.
MODS:
Old 04-01-2015, 08:23 PM   #7
mikepage0007
Drives: 2010 camaro
seems from what I have heard , this appears to be a bearing..guess it comes off this wek and off to whipple to see what they find..
Old 04-01-2015, 09:04 PM   #8
CoupeSS
CoupeSS's Avatar
Drives: 2013 Coupe 2SS/RS
Remember when we were kids we would put cards on your bicycle forks to make noise on the spokes? Well maybe I should put a whistle in my grill to make fake wimple wine so it sounds like I am going fast!!!
CoupeSS is offline   Reply With Quote
Old 04-01-2015, 10:11 PM   #9
mikepage0007
Drives: 2010 camaro
or just do this..lol
Old 04-01-2015, 10:56 PM   #10
CoupeSS
CoupeSS's Avatar
I am rolling with tears!! Especially sense my company car is a Prius!!! ��������
Old 04-02-2015, 08:24 AM   #11
DARKTHIRTY777
DARKTHIRTY777's Avatar
Drives: 2011 camaro ss
Lmao. I'm so using that app in the wife's GMC Terrain
2011 ls3 ss/rs, Kooks long tube headers, gutted high flow cats, 231/239. 624" lifted squared 115+3 lsa comp cam, ecs supercharger, Alky methanol kit, DSS 1000hp axles, BMR toe rods, BMR trailering arms, Fore innovations dual fuel pump. Flex fuel sensor and 360 custom tunes, hp tuners NGAUGE. 752 hp with 93 octane and 825 hp with E85.
DARKTHIRTY777 is offline   Reply With Quote
Old 04-02-2015, 10:28 PM   #12
Supermaro54
Supermaro54's Avatar
Drives: 68,87,99 camaro,07TBSS
what pulley combo are you running? I think I'll be shipping mine next. It's starting to sound the same way, just not as loud.
2007 TBSS, forged 6.2, 2.9 whipple 9.9@135
(Now with CNC LSA, Numbers coming soon)
1999 Camaro SS, CNC LSA, 4L80, S60
1987 Camaro Iroc-Z, ZR1 blower, TR6060, S60
1968 Camaro SS, YSI 427 ERL in the works.
Supermaro54 is offline   Reply With Quote
Old 04-03-2015, 08:31 AM   #13
mikepage0007
Drives: 2010 camaro
can,t remember, we built the infamous adm independent 10 rib built system..the 10 rib runs olnly the sc pulley..using a gt500 pulley-a zl1 tensioner and a Cadillac balancer if I recall..running around 15psi..we had a 18psi pulley on the whipple, but after doing the math, we whaer oeverspining the whipple around 20000rpm..i believe whipple is around 18500rpm maximum..if I recall , we are just under that by approx. 300rpm @ 15psi
Old 04-04-2015, 06:35 PM   #14
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
Is this a common problem with supercharges? Or is it because it was spinning to fast? How long should the bearings last before they need to be replaced? And when they need replacing does it have to be sent back to whipple? Sorry for all the questions, but I'm looking to purchase this supercharge.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
